Save as in macro works, save as it does not work in ilogic
Sergio.D.Suárez
Mentor Mentor
Sergio.D.Suárez
Hi everybody, i have a doubt,
Because this routine in macro works perfectly and this routine in ilogic does not perform any action?
MACRO
Sub RunCommand()
    ' Get the CommandManager object.
    Dim oCommandMgr As CommandManager
    Set oCommandMgr = ThisApplication.CommandManager
    ' Get control definition for the line command.
    Dim oControlDef As ControlDefinition
    Set oControlDef = oCommandMgr.ControlDefinitions.Item("AppFileSaveAsCmd")
    ' Execute the command.
    Call oControlDef.Execute
End Sub
ILOGIC
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
bradeneuropeArthur
with this it works:
	'MsgBox (oControlDef.DisplayName)
    oControlDef.Execute2(False)
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Sergio.D.Suárez
thank you very much Arthur!!!, you are a genius!!!
Mechanical Designer
bradeneuropeArthur
@Sergio.D.Suárez
Good to hear that it works now!
Your thanks are appreciated.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
walter_diepstraten
Bedankt
