Save As DWF for Multi-Sheet IDW
I downloaded the code below from Kent's KWIK MCAD iCode Page
It works perfectly for a single sheet IDW
If I use it on a Multi-Sheet IDW it only creates the 1st Sheet in the DWF...
What I want is for a Multi-Sheet DWF to be created, I Know Inventor 7 can do
it...
Yoni Rogel
the iCode fron Kent's:
Option Explicit
Public Sub SaveAsDwf()
ThisApplication.SilentOperation = True
Dim oDoc As DrawingDocument
Dim oSheet As Inventor.Sheet
Dim oDataIO As DataIO
Set oDoc = ThisApplication.ActiveDocument
Set oSheet = oDoc.Sheets(1)
Dim fname As String
fname = oDoc.FullFileName
fname = Left(fname, Len(fname) - 3) & "dwf"
If UpdateDrawing(oDoc) = True Then
Set oDataIO = oDoc.Sheets(1).DataIO
Call oDataIO.WriteDataToFile("DWF", fname)
End If
ThisApplication.SilentOperation = False
End Sub
Making it iterate through the sheets would be easy enough, but I am not sure how to cause
it to all be exported to one DWF. Also be aware I have had a number of people say that
when they run this on one file it works OK, but if they batch run it the fonts get messed
up. I submitted it to Autodesk, but it got passed from one group to the other and I have
never heard back anything on it.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Yoni Rogel" wrote in message
news:03EEA8F2E4AA0B17AC6B1FC34C478105@in.WebX.maYIadrTaRb...
It might be that this is only supported in R7. I am getting multiple
sheet DWF's from IV7 Pro. I don't have IV7 installed. Might be worth
checking if there are DWF export updates for other versions. Another
possibility (which I am starting to look into) is to use the DWF toolkit
and try merging them but I can't seem to find my VC++ CD's to install
the missing Unicode support so it could be a while before I get to play
with it.
>Kent
>Assistant Moderator
multi sheet dwf was added in r7
-kevin
DWF...
do
> it...
> Thanks
> Yoni Rogel
> Option Explicit
> Dim fname As String
> End If
> End Sub
Are you saying the ability was added to the API or just manually through
the SaveCopyAs dialog?
Kent Keller
http://www.MyMcad.com/KWiK/Mcad.htm
Assistant Moderator
"Kevin Schneider (Autodesk, Inc.)" wrote
in message news:2967C5F9800B9CAB236DAC7C6454ADCC@in.WebX.maYIadrTaRb...
> -kevin
the
> DWF...
7 can
> do
> > it...
> > Thanks
> > Yoni Rogel
> > Option Explicit
> > Dim fname As String
> > End If
> > End Sub
I happens automatically via "Save Copy As" ala:
oCmdMgr.PostPrivateEvent kFileNameEvent, sDWFFilename
oCmdMgr.StartCommand kFileSaveCopyAsCommand
