Activate Assembly Component
How do I activate a assembly component just like If I double clicked on it in the browser.
I know I don't need to do this to work on the part with code, but currently all I am
wanting to do is just activate it.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
Nevermind. I found what I was doing wrong. Now I just need to figure out how to get a
reference to it 8^)
Kent
Assistant Moderator
"Kent Keller" wrote in message
news:DF1073B964237FB97F3D98E1BDBC3EBC@in.WebX.maYIadrTaRb...
Does oDoc.ActivatedObject do anything for you?
Neil
news:FE3ABE9F19AE7727E6C20013883CD85F@in.WebX.maYIadrTaRb...
out how to get a
> reference to it 8^)
> Kent
> Assistant Moderator
The problem is I can easily get a reference to a PartDocument or AssemblyDocument, such as
what odoc.ActivatedObject would return, but how do I get the Occurrence from that.
This is what I figured I need to activate the assembly occurrence. Or is there a way to
activate it if I just have the PartDocument object? I tried activate but didn't have any
luck.
oDoc.ComponentDefinition.Occurrences.Item(1).Edit
Kent
Assistant Moderator
"Neil Munro" wrote in message
news:1B4B80AA851F7E7BC9F2501D92476CB8@in.WebX.maYIadrTaRb...
> Neil
> out how to get a
> > reference to it 8^)
> > Kent
> > Assistant Moderator
Yes, the Edit method activates the occurrence just as if you had
double-clicked it in the browser. How are you deciding which component to
edit (sorry if I'm asking the same question you are?)
Neil
news:7F893E256B59899B89CB13EE54836CAD@in.WebX.maYIadrTaRb...
from that.
there a way to
didn't have any
> luck.
> Kent
> Assistant Moderator
> > Neil
figure
> > out how to get a
> > > reference to it 8^)
> > > Kent
> > > Assistant Moderator
Neil helped me with a method to be able to activate "A" occurrence (the first one in a
assembly) of the part, but not necessarily the one that was originally edited.
I hope this is just a oversight and that we will have more access to occurrences in a
application or document event in future releases.
Kent
Assistant Moderator
news:C3F3051E04DE97408C955147F76311ED@in.WebX.maYIadrTaRb...
