Message 1 of 15
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to modify a rule i acquired to have it save and replace all parts in an iam that begin with only the characters "Project" since there are content center parts i cant have these be replaced. Also, there are children iams in the parent iam i wish to save and replace as well.
For example original file name is "Project-200000 FRAME SIDE A" I'd like to replace only "Project" with 5 characters such as 25100 for example. Can anyone help me with this?
Below is the code i'm working with and attached in a txt file.
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then MsgBox("This rule '" & iLogicVb.RuleName & "' only works for Assembly Documents.",vbOK, "WRONG DOCUMENT TYPE") Return End If Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument Dim oFileDlg As Inventor.FileDialog = Nothing ThisApplication.CreateFileDialog(oFileDlg) oFileDlg.Filter = "Autodesk Inventor Assembly Files (*.iam)|*.iam" oFileDlg.InitialDirectory = ThisApplication.DesignProjectManager.ActiveDesignProject.WorkspacePath oFileDlg.FileName = IO.Path.GetFileName(oADoc.FullFileName).TrimEnd("."c,"i"c,"a"c,"m"c) oFileDlg.DialogTitle = "Specify New Name & Location For Copied Assembly" oFileDlg.CancelError = True On Error Resume Next oFileDlg.ShowSave If Err.Number <> 0 Then MsgBox("No File Saved.", vbOKOnly, "DIALOG CANCELED") ElseIf oFileDlg.FileName <> "" Then oNewFileName = oFileDlg.FileName oADoc.SaveAs(oNewFileName, False) End If oADoc = Nothing InventorVb.DocumentUpdate() oADoc = ThisApplication.ActiveDocument ' Get the new base name without extension and path Dim oNewBaseName As String = IO.Path.GetFileNameWithoutExtension(oADoc.FullFileName) ' Extract the new prefix (everything before the first hyphen) Dim oNewPrefix As String = "" Dim oHyphenPos As Integer = oNewBaseName.IndexOf("-") If oHyphenPos > 0 Then oNewPrefix = oNewBaseName.Substring(0, oHyphenPos) End If ' Calculate how many characters to keep from original name (excluding "Project") ' Based on your example: "Project-100000" -> "250001-100000" ' We keep 8 characters total, minus 6 for "Project" = 6 characters after "Project" Dim oCharsToKeepAfterProject As Integer = oNewBaseName.Length - oNewPrefix.Length Dim oReferenceSuffix As String For Each oRefDoc As Document In oADoc.AllReferencedDocuments ThisApplication.Documents.Open(oRefDoc.FullFileName,False) ' Get original filename without extension Dim oOriginalName As String = IO.Path.GetFileNameWithoutExtension(oRefDoc.FullFileName) ' Check if it starts with "Project" and extract the suffix If oOriginalName.StartsWith("Project") And oOriginalName.Length > 7 Then ' Take the specified number of characters after "Project" Dim oAfterProject As String = oOriginalName.Substring(7) If oAfterProject.Length >= oCharsToKeepAfterProject Then oReferenceSuffix = oAfterProject.Substring(0, oCharsToKeepAfterProject) Else oReferenceSuffix = oAfterProject ' Use all available characters if less than needed End If Else ' If it doesn't start with "Project", use a fallback approach ' You might want to modify this based on your specific needs oReferenceSuffix = oOriginalName End If ' Save with new naming convention If oRefDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then oRefDoc.SaveAs(Left(oADoc.FullFileName, Len(oADoc.FullFileName) -4) & "\" & oNewPrefix & oReferenceSuffix & ".ipt", True) ElseIf oRefDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then oRefDoc.SaveAs(Left(oADoc.FullFileName, Len(oADoc.FullFileName) -4) & "\" & oNewPrefix & oReferenceSuffix & ".iam", True) End If oRefDoc.Close Next Dim oOccDoc As Document Dim oOccNewFileName As String For Each oOcc As ComponentOccurrence In oADoc.ComponentDefinition.Occurrences oOccDoc = oOcc.Definition.Document ' Get original filename without extension Dim oOriginalName As String = IO.Path.GetFileNameWithoutExtension(oOccDoc.FullFileName) ' Check if it starts with "Project" and extract the suffix If oOriginalName.StartsWith("Project") And oOriginalName.Length > 7 Then ' Take the specified number of characters after "Project" Dim oAfterProject As String = oOriginalName.Substring(7) If oAfterProject.Length >= oCharsToKeepAfterProject Then oReferenceSuffix = oAfterProject.Substring(0, oCharsToKeepAfterProject) Else oReferenceSuffix = oAfterProject End If Else oReferenceSuffix = oOriginalName End If ' Build new filename If oOccDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then oOccNewFileName = Left(oADoc.FullFileName,Len(oADoc.FullFileName)-4) & "\" & oNewPrefix & oReferenceSuffix & ".ipt" ElseIf oOccDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then oOccNewFileName = Left(oADoc.FullFileName,Len(oADoc.FullFileName)-4) & "\" & oNewPrefix & oReferenceSuffix & ".iam" End If oOcc.Replace(oOccNewFileName, True) Next
