Dim rectPattern = Patterns.AddRectangular
tomislav.peran
tomislav.peran
I am struggling to find the solution for the following.
I have a List of Strings representing Occurence Names that I added into an assembly, like Pen:1, Pen:2 etc.
addedPens As List(Of String)
That I converted to List of ManagedCompOcurrences, just to try if pattern will work.
Dim componentRefs As New List(Of ManagedComponentOccurrence)
	For Each name In addedPens
		'use Pens names to get the correct object
		componentRefs.Add(Components.Item(name))
	Next
However, when I use both Lists as an argument in:
Dim rectPattern = Patterns.AddRectangular("test", componentRefs , 3, 3000, _
I constantly get errors.
I tried converting both Lists to an Array but that failed as well.
I even tried declaring Argument as:
Dim compOrPattern As New ComponentOrPattern(componentRefs), because it says in the documentation:
ComponentOrPattern(IEnumerable(Object))
Construct from a list of objects. If one of the items is not convertible to a ComponentOrPattern, an exception will be thrown.
Does anyone have experience with this? Any help is welcome.
Tom
JMGunner
This was only soultion i find
too add more componets
Best  JM
Value = Qty Value = Size
Patterns.Delete("SupportPattern")
''Qty of Componetents
Dim compPatterns(2) As ComponentOrPattern
compPatterns(1) = "Support"
compPatterns(0) = "Support2"
compPatterns(2) = "Support5"
Patterns.AddRectangular("SupportPattern",compPatterns, Qty, Size, "", "X Axis")
tomislav.peran
Hey man, this approach with Array of ComponentOrPattern works.  I can use this.
Have a nice day a thank you very much for helping out!
Tom
