Save a IDW as PDF from assembly
Hello
How can i save a IDW file from Assrmbly to a PDF, without opening that IDW?
Thank you
Aleksandar Jovicic
CCarreiras
Hi!
If you dont open the idw... it will not update... are you shure that it is what you want?
CCarreiras
Hey
Uf thats a problem now
Then i muss he open save and close option use?
MechMachineMan
He is correct that you must open it, but you can just open it invisibly, update it, save it, run your code, and close it.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Hello
And where can i find that "invisibility" option.
Aleksandar Jovicic
CCarreiras
Hi!
It's a very bad idea to have 3D ilogic and 2d documents open at the same time.
Usually is a can of error alerts and malfunctions.
The best workflow is: configure the 3D Model.... close it............... and finnally open the 2d documents to document the model to production, purchases, etc.
CCarreiras
Sorry but i dont undertend yet 😄
