Run VBA from Inventor addin?!
I wrote a VBA Code and now wanted it to start after click on save, but Autodesk deaktivated the option for makros.
I wonder now if this code still works, because I cant see any resault and the vb.net is new for me... maybe code doesnt work anymore or I make some misstakes?
http://adndevblog.typepad.com/manufacturing/vladimir-ananyev/page/6/
Public Sub RunMacro_VBA()
  Dim m_inventorApp As Inventor.Application = Nothing
  ' Try to get an active instance of Inventor
  Try
    m_inventorApp = System.Runtime.InteropServices _
     .Marshal.GetActiveObject("Inventor.Application")
  Catch ex As Exception
  End Try
  ' If not active, create a new Inventor session
  If m_inventorApp Is Nothing Then
    Dim inventorAppType As Type = System _
     .Type.GetTypeFromProgID("Inventor.Application")
    m_inventorApp = System.Activator _
         .CreateInstance(inventorAppType)
  End If
  Dim oP As Inventor.InventorVBAProject
  For Each oP In m_inventorApp.VBAProjects
    If oP.Name = "ApplicationProject" Then
      Dim oC As Inventor.InventorVBAComponent
      For Each oC In oP.InventorVBAComponents
        If oC.Name = "Module1" Then
          Dim oM As Inventor.InventorVBAMember
          For Each oM In oC.InventorVBAMembers
            If oM.Name = "MyFunction" Then
              oM.Execute()
            End If
          Next oM
        End If
      Next oC
    End If
  Next
End Sub
I edited
Module1 = CreateView
MyFunktion = VBAToExecute
The Module "CreateView" is in "ApplicationProject" (Default.ivb).
Alternative I can translate the VBA to a VB.net, but it was hard enough to me to create the vba code. 😞
Owner2229
Hey, I used to use this too, so I know it works, but hey, here's a simplified version:
    For Each oProject As Inventor.InventorVBAProject In m_InventorApp.VBAProjects
        If oProject.Name <> "ApplicationProject" Then Continue For
        Dim oComp As Inventor.InventorVBAComponent = oProject.InventorVBAComponents("Module1")
        Dim oMember As Inventor.InventorVBAMember = oComp.InventorVBAMembers("MyFunction")
        Try
            oMember.Execute()
        Catch
        End Try
    Next
Just make sure all the called Subs are Public:
Public Sub MyFunction()
    'Code
End Sub
Also, I would suggest you learning VB.Net, translating all your rules to it (over time, e.g. half a year) and moving them to an AddIn. It'll give you much more options and control over what you're doing.
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Thank you. Didnt name the Sub "Public". Now it works.
I think I will learn vb.net in the future. Tanks again and have a nice day!
