iLogic: Allow multiple filters for the Pick function
DRoam
Mentor Mentor
DRoam
I know I can use the Pick function to select objects using iLogic. I know the filter for Planes is "SelectionFilterEnum.kWorkPlaneFilter", and for Sketches it's "SelectionFilterEnum.kSketchObjectFilter".
But what if I want to have a pick function that will allow me to select a plane OR a sketch? Is there any way to specify multiple filters for a Pick function? Something like:
ThisApplication.CommandManager.Pick(SelectionFilterEnum.kWorkPlaneFilter & SelectionFilterEnum.kSketchObjectFilter,"Select a Plane or Sketch:")
Is this possible? If not, can I specify a "filter" that will allow me to select anything, so I can select either a plane or a sketch and then just give an error if something else is selected?
Jef_E
I don't know about selecting multiple object types with a filter.
This filter allows you to select anything.
kAllEntitiesFilter 18439 All entities filter(all entities should be selectable).
Maybe you could create your own "Pick fuction" but it will be a bit more complicated 😄
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
frederic.vandenplas
This filter is probably better to use
ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPlanarEntities, "Select a Plane or Sketch:")
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
SometimesInventorMakesMeAngry
Can you explain how one would do this? I can write the code, I just need a direction.
I'm writing a small macro to add measuring functionality and I need several different entity types to be selectable.
