Run Rule in Another Document
Does anyone know if there's a code for running a rule in another document once it is added?
Currently, I have a rule in my part doc that adds a new drawing document from a custom template. I want to make it so that once the drawing document is opened, it automatically runs another rule, i.e. a rule that adds views and dimensions.
However I want to do this without using triggers in the drawing document. I want it so the rule is run only when the drawing document is created from the specific part doc, not just any part doc.
MechMachineMan
iLogicAuto.RunExternalRule(oDoc, "RuleName")
iLogicAuto.RunRule(oDoc, "RuleName")
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Appreciate it.
Hmm... doesn't seem to be working. I may have implemented it wrong.
Here is my code
SyntaxEditor Code Snippet
ThisApplication.RunRule(ThisApplication.Documents.Item(ThisApplication.Documents.Count), "CREATE DRAWING")
I have this code within a rule inside inventor and am using it to run another rule in a drawing document that was just added by the same rule that this code resides in.
Hi Thukon,
Can you post the rule you have in your part document ?
And do you already have the code to create the specific views?
Here is the code. The line for running the rule in the drawing document is the second to last line in the code. I even added a message box that says "loaded" before the runrule line so that I could give time for the drawing document to open up.
And yes I already have the rule in my drawing document for creating the specific views.
'define the active document
oDoc = ThisApplication.ActiveDocument
'create a file dialog box
Dim oFileDlg As inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
'check file type and set dialog filter
If oDoc.DocumentType = kPartDocumentObject Then
oFileDlg.Filter = "Autodesk Inventor Part Files (*.ipt)|*.ipt"
Else If oDoc.DocumentType = kAssemblyDocumentObject Then
oFileDlg.Filter = "Autodesk Inventor Assembly Files (*.iam)|*.iam"
Else If oDoc.DocumentType = kDrawingDocumentObject Then
oFileDlg.Filter = "Autodesk Inventor Drawing Files (*.idw)|*.idw"
'set the directory to open the dialog at
oFileDlg.InitialDirectory = ThisDoc.WorkspacePath()
'set the file name string to use in the input box
oFileDlg.FileName = iProperties.Value("Project", "Part Number")
'work with an error created by the user backing out of the save
oFileDlg.CancelError = True
On Error Resume Next
'specify the file dialog as a save dialog (rather than a open dialog)
oFileDlg.ShowSave()
'catch an empty string in the imput
If Err.Number <> 0 Then
MessageBox.Show("No File Saved. You must save the file before creating a drawing", "Error")
ElseIf oFileDlg.FileName <> "" Then
MyFile = oFileDlg.FileName
'save the file
oDoc.SaveAs(MyFile, False) 'True = Save As Copy & False = Save As
MessageBox.Show(ThisDoc.Path & "\" & oDoc.DisplayName," ")
ThisApplication.documents.add(kDrawingDocumentObject, "C:\Users\Public\Documents\Autodesk\Inventor 2014\Templates\STSH Standard 2015.idw", True)
MessageBox.Show("Loaded")
iLogicVb.RunRule(ThisApplication.Documents.Item(ThisApplication.Documents.Count), "CREATE DRAWING")
