Run Inventor Update Design Or Ilogic Code through JobProcessor
acanx21
acanx21
We are currently having issues with Task Scheduler no longer working for checking files in so we are trying to come up with a different way to run the update design on all our parts. (We have an ilogic rule that runs on save to check all the information inside the parts and Update design makes sure this rule runs before we release).
I have not been able to find any documentation on it so far. Can anyone point me in the correct direction for either running Inventor Update design through JobProcessor or a way to run an ilogic code in files through JobProcessor if either of those are possible.
Thank you!
Markus.Koechl
Hi, you are right - we "silently" added the capability but to make a benefit out of it you need to have a custom Vault Job capable to fire the rules. I am going to share documentation and access to all you need during AU 2020; so watch out for the class IM468712 - iLogic & Vault | Vault & iLogic once registration is open. Part 2 of this class provides insights to solve tasks like this. Get a sneak preview here:
[video]
The source code is available https://github.com/koechlm/Vault-Job-Processor---iLogic-Extension/tree/2021 (a 2020 branch exists also) and an installable will follow before AU.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
