How do I control flip bend direction with iLogic
gma
gma
HI,
How do i flip my bend direction with an iLogic code. (Left/Right)
Thanks in advance
JhoelForshav
Hi @gma
The bend feature has the boolean property BendInSketchNormalDirection. You can change it like this 🙂
Dim oDoc As PartDocument = ThisDoc.Document
oDoc.ComponentDefinition.Features.BendPartFeatures.Item(1).BendInSketchNormalDirection = False 'False/True
If the feature is named "Vinkel" as in your picture. This rule will flip the direction everytime you run it 🙂
Dim oBend As BendPartFeature = oDoc.ComponentDefinition.Features.BendPartFeatures.Item("Vinkel")
If oBend.BendInSketchNormalDirection
	oBend.BendInSketchNormalDirection = False
Else
	oBend.BendInSketchNormalDirection = True
gma
Thank you very much.
My problem is solved.
Regards
GMA
