Run external iLogic rule using macro
martinhoos
Message 1 of 11
martinhoos
Hello all,
i am looking for a solution to run a external ilogic rule with yes/no out of a macro. I dont find any samples....  😞
Sub Stl_Export_LN()
If MsgBox("Möchtest Du eine Plausibilitaetsprüfung?", vbYesNo + vbQuestion) = vbYes Then
iLogicVb.RunExternalRule ("Plausibilitaetsprüfung")
End Sub
If the answer is yes, the ilogic shouldt be run and after that returns to the macro.
Hopeful this is possible.
Regards
Martin
Replies (10)
Message 2 of 11
MechMachineMan
Uhhhhh.....
https://forums.autodesk.com/t5/inventor-customization/launch-external-ilogic-rule-with-vba/td-p/3170...
From the link above, to run iLogic from VBA environment...
Public Sub LaunchMyRule1() '<--- "LaunchMyRule1" would be what shows up in the toolbar.
  RuniLogic "MyRule1"
End Sub
Public Sub LaunchMyRule2()
  RuniLogic "MyRule2"
End Sub
Public Sub RuniLogic(ByVal RuleName As String)
  Dim iLogicAuto As Object
  Dim oDoc As Document
  Set oDoc = ThisApplication.ActiveDocument
  If oDoc Is Nothing Then
    MsgBox "Missing Inventor Document"
    Exit Sub
  Set iLogicAuto = GetiLogicAddin(ThisApplication)
  If (iLogicAuto Is Nothing) Then Exit Sub
  iLogicAuto.RunExternalRule oDoc, RuleName
End Sub
Function GetiLogicAddin(oApplication As Inventor.Application) As Object
  Dim addIns As ApplicationAddIns
  Set addIns = oApplication.ApplicationAddIns
  Dim addIn As ApplicationAddIn
  Dim customAddIn As ApplicationAddIn
  For Each addIn In addIns
    If (addIn.ClassIdString = "{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}") Then
        Set customAddIn = addIn
        Exit For
  Next
  Set GetiLogicAddin = customAddIn
End Function
As an extra, to run VBA from iLogic, it looks something like this:
Dim invApp As Inventor.Application
invApp = ThisApplication
'To implement, you almost certainly need to change the indices (values in brackets) to match your code. invApp.VBAProjects(1).InventorVBAComponents("AppEventController").InventorVBAMembers("StartEvent").Execute
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 11
chandra.shekar.g
Autodesk Support
Autodesk Support
@MechMachineMan
That's nice information.
@martinhoos,
Try the below VBA code to run rule if the answer is yes.
Sub Stl_Export_LN()
	RuniLogic ("Plausibilitaetsprüfung")
End Sub
    Exit Sub
End Sub
        Exit For
  Next
End Function
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 4 of 11
martinhoos
Hi Chandra,
thanks for your reply. This code is like spanish to me - i dont understand  😞
Please, can you explain or Change the code for me  🙂
The Problem i have is a very old vba code, this code i have to Change with a question at the beginning. And if that question is answered with "yes" an external iLogic code shouldt runs... and after that the vba code shouldt finish... The old vba code is not that big - but i did not get change it to ilogic 😞
Hopefully you can hlep me....
Thank you in advance
Regards
Martin
Message 5 of 11
chandra.shekar.g
Autodesk Support
Autodesk Support
@martinhoos
Below VBA code is to get iLogic addin to run a rule by mentioning rule name.
    Exit Sub
End Sub
        Exit For
  Next
End Function
Below code is to run rule by calling above function RuniLogic. If the answer is Yes from message box.
Sub Stl_Export_LN()
End Sub
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 6 of 11
MechMachineMan
@martinhoos You cannot make the program jump between 2 rules concurrently.
Your best option here is to have the iLogic rule that I (and @chandra.shekar.g) posted run as your main vba rule, and embed the question within it, and then run the iLogic rule from it as needed.
If you have the question built into the external rule, just have the VBA fire the rule and DO NOT put the question in the VBA as it already exists in the rule.
If you would post more of your code, perhaps we could rewrite it or explain it better for you.
Justin K
Message 7 of 11
Curtis_W
From iLogic you can also just use this line to call a VBA macro
	'call VBA Macro
    InventorVb.RunMacro("ApplicationProject", "Module1", "MyMacro")
I hope this helps.
Curtis
Message 8 of 11
martinhoos
Hi all, thanks again for your replies. This will help me.
Regards Martin
Message 9 of 11
JasonMayes
this part is giving me fits. it errors out. it is probably something simple... any help?
Message 10 of 11
Darkforce_the_ilogic_guy
I have the same problem...and I just need a simple marco to start one ilogic rule
Message 11 of 11
JasonMayes
Without to much work I was able to manipulate the code found here and get it to work.
https://www.cadlinecommunity.co.uk/hc/en-us/articles/115000859309-Inventor-Run-iLogic-Rules-from-you...
