Exclude from print if Model iProperty exists
dliteful
dliteful
Love the iLogic Batch print to PDF from assembly, but I've been asked to exclude certain file types that contain the Model iProperty Value of "SPA" under the Summary Tab in Category field.
Any help would be greatly appreciated.
Attached is the code I'm using.
JhoelForshav
Try this 🙂 I just added the condition check the iproperty in the same if-statement where you make sure the referenced document is an assembly.
'This targets all assembly file drawings.
'This will hide the PART NUMBER & SPECIFICATION fields in the BOM on all sheets and convert the file to PDF
Sub Main()
	Dim oAsmDoc As AssemblyDocument
	oAsmDoc = ThisApplication.ActiveDocument
	oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
	'check that the active document is an assembly file
	If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
		MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
		Exit Sub
	'get user input
	If MessageBox.Show ( _
		"This will create a PDF file for all related assembly drawings that have drawings files." _
		& vbLf & " " _
		& vbLf & "This rule expects that the drawing file shares the same name and location as the component." _
		& vbLf & " " _
		& vbLf & "Are you sure you want to create PDF Drawings for all of the assembly drawings?" _
		& vbLf & "This could take a while.", "iLogic  - Batch Output PDFs ",MessageBoxButtons.YesNo) = vbNo Then
		Exit Sub
	Dim PDFAddIn As TranslatorAddIn
    Dim oContext As TranslationContext
	Dim oOptions As NameValueMap
	Dim oDataMedium As DataMedium
	Call ConfigurePDFAddinSettings(PDFAddIn, oContext, oOptions, oDataMedium)
	'Get PDF folder path
	oPath = ThisDoc.Path
	oFolder = oPath & "\" & "_Customer PDF - " & oAsmName
	'Create PDF folder if it does not exist
	If Not System.IO.Directory.Exists(oFolder) Then
		System.IO.Directory.CreateDirectory(oFolder)
	'- - - - - - - - - - - - -Component Drawings - - - - - - - - - - - -'
	'Look at the files referenced by the assembly
	Dim oRefDoc As Document
	For Each oRefDoc In oAsmDoc.AllReferencedDocuments
		'Target Assembly Files Only
			If oRefDoc.DocumentType = kAssemblyDocumentObject _
			AndAlso oRefDoc.PropertySets.Item("Inventor Document Summary Information").Item("Category").Value <> "SPA" Then
			'Dim oAsmDrawDoc As AssyDrawDocument
			oAsmDrawDoc = oRefDoc
		idwPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentNaMe) - 3) & "idw"
		If(System.IO.File.Exists(idwPathName)) Then
			Dim oDrawDoc As DrawingDocument
			oDrawDoc = ThisApplication.Documents.Open(idwPathName, True)
			oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName) -4)
			oRevNum = oDrawDoc.PropertySets.Item("Inventor Summary Information").Item("Revision Number").Value
			'Convert BOM to customer friendly version
			iLogicVb.RunExternalRule("AED BOM")
			On Error Resume Next
			'Set the PDF target file name
				If oRevNum = Nothing Then
					oDataMedium.FileName = oFolder & "\" & oFileName & ".pdf"
				Else
					oDataMedium.FileName = oFolder & "\" & oFileName & " Rev." & oRevNum & ".pdf"
				Call PDFAddIn.SaveCopyAs(oDrawDoc, oContext, oOptions, oDataMedium)
				oDrawDoc.Close(True)
			On Error Goto 0
	Next
	'- - - - - - - - - - - - -Top Level Drawing - - - - - - - - - - - -
	Dim oAsmDrawingDoc As DrawingDocument
	oAsmDrawingDoc = ThisApplication.Documents.Open(ThisDoc.ChangeExtension(".idw"), True)
	oAsmDrawingName = Left(oAsmDrawingDoc.DisplayName, Len(oAsmDrawingDoc.DisplayName) -4)
	oAsmDrawingRev = oAsmDrawingDoc.PropertySets.Item("Inventor Summary Information").Item("Revision Number").Value
				If oAsmDrawingRev = Nothing Then
					oDataMedium.FileName = oFolder & "\" & oAsmDrawingName & ".pdf"
				Else
					oDataMedium.FileName = oFolder & "\" & oAsmDrawingName & " Rev." & oRevNum & ".pdf"
		Call PDFAddIn.SaveCopyAs(oAsmDrawingDoc, oContext, oOptions, oDataMedium)
		oAsmDrawingDoc.Close(True)
	MessageBox.Show("New Files Created in: " & vbLf & oFolder, "iLogic")
	Shell("explorer.exe " & oFolder,vbNormalFocus)
End Sub
Sub ConfigurePDFAddinSettings(ByRef PDFAddIn As TranslatorAddIn, ByRef oContext As TranslationContext, ByRef oOptions As NameValueMap, ByRef oDataMedium As DataMedium)
	PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
	oContext = ThisApplication.TransientObjects.CreateTranslationContext
	oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
	oOptions = ThisApplication.TransientObjects.CreateNameValueMap
	oOptions.Value("All_Color_AS_Black") = 1
	oOptions.Value("Remove_Line_Weights") = 1
	oOptions.Value("Vector_Resolution") = 400
	oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
	'oOptions.Value("Custom_Begin_Sheet") = 1
	'oOptions.Value("Custom_End_Sheet") = 1
	oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
End Sub
Sergio.D.Suárez
The truth is I've lost a bit because I have no way to prove the rule since I do not have drawing files like those described, but I guess the way to solve would be acting on the action of saving, I added this line so that in case the property is different to "SPA" it will save the pdf.
					oCateg = oDrawDoc.PropertySets.Item("Inventor Document Summary Information").Item("Category").Value
					If oCateg <> "SPA" Then
 If you do not work the other paths try the rule.
Sub Main()
	oAsmDoc = ThisDoc.Document
		Exit Sub
	'get user input
		& vbLf & " " _
		& vbLf & " " _
		Exit Sub
			If oRefDoc.DocumentType = kAssemblyDocumentObject Then
					Else
					On Error GoTo 0
	Next
				Else
				oCateg = oAsmDrawingDoc.PropertySets.Item("Inventor Document Summary Information").Item("Category").Value
End Sub
End Sub
I hope you can solve the problem
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
dliteful
Perfect!  Thank you so much.  I knew it had to be something simple.
