Run a rule after savin the linked excel tabell
Message 1 of 8
Hi
Is there a way to run the rule after savin a excel tabell?
Replies (7)
Message 2 of 8
Amit_11
Could you please elaborate, what exactly are you looking for?
Message 3 of 8
Yes
I have define a rule to update a assembly design, when i save a excel tabell (with paramters).
I want to update the parameters, but withot using the update butto in inventor.
So, just save the excel and the file automaticlly update.
Message 4 of 8
Amit_11
One way to update the Assembly/Part is by Running the Rule to read the Excel Table with Event Trigger (Before Save),
Message 5 of 8
And ist there a way when i change the parameters in excel, and after saving it?
Message 6 of 8
Amit_11
I am not sure if you are using Ilogic rules to read the Excel table or The Excel table is embedded into the file. Here I am attaching a test file, in this file excell file is embedded and a rule has been added to the file, which is triggered on any change in parameter.
The result is moment the excel file is saved, the part gets updated.
If you are writing a ilogic code to read the excel file, then the treatment will be different.
Message 7 of 8
Thank you it works
Can i make the excel file open when I open the file.
By me, i have make a excel file, that is with a assembly linked, and i open the file with that excel (a hyperlink).
When i save the tabell, not of all parameters all update. i muss save the tabell and then activate the update butto
how du you define that rule "new part asembly"?
where is it?
Message 8 of 8
 how du you use trigger???
