Lock customization
Lock customization
Lock customization
I would like to know if there is any way to look the user options / customizations of Inventor, so I can choose one and then nobody can change.
Thanks!
Vladimir.Ananyev
In general, not. You may create an Inventor  addin that could check/restore some critical settings during startup.
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
MechMachineMan
You can export and have your options saved as a backup; and it may be possible to write some program to check for if any are changed and re-import the standard set.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
