Rule with multiple options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
This is a long one.
I make doors. They can be different Widths and Heights, among different Types.
Widths:
3-6 (41.75")
3-0 (35.75")
2-10 (33.75")
2-8 (31.75")
2-6 (29.75")
Heights:
8-0 (95.375")
6-8 (79.375")
Types:
1K (1-Panel)
2K (2-Panel
3F (3-Panel)
3S (3-Panel w/ Glass)
50 (5-Panel)
I have a Width Param & Rule:
DoorWidthOptions [Text, Multi]: 3-6, 3-0, 2-10, 2-8, 2-6
DoorWidth [Num]: (Varies)
Door Width Rule:
'Door Width If DoorWidthOptions = "3-6" Then DoorWidth = 41.75 End If If DoorWidthOptions = "3-0" Then DoorWidth = 35.75 End If If DoorWidthOptions = "2-10" Then DoorWidth = 33.75 End If If DoorWidthOptions = "2-8" Then DoorWidth = 31.75 End If If DoorWidthOptions = "2-6" Then DoorWidth = 29.75 End If
I have a Height Param & Rule:
Works same as width, except with the 2 Height options
DoorHeightOptions [Text, Multi]: 8-0, 6-8
DoorHeight [Num]: (Varies)
Door HeightRule:
'Door Height If DoorHeightOptions = "6-8" Then DoorHeight = 79.375 End If If DoorHeightOptions = "8-0" Then DoorHeight = 95.375 End If
I have a Door Type Rule: Same rule for all other types as well, not just '1K'
If DoorType = "1K" Then Component.IsActive("1K Skin: Back") = True Component.IsActive("1K Skin: Front") = True Component.IsActive("2K Skin: Back") = False Component.IsActive("2K Skin: Front") = False Component.IsActive("3F Skin: Back") = False Component.IsActive("3F Skin: Front") = False Component.IsActive("3F (3-6) Skin: Back") = False Component.IsActive("3F (3-6) Skin: Front") = False Component.IsActive("3S Skin: Back") = False Component.IsActive("3S Skin: Front") = False Component.IsActive("50 Skin: Back") = False Component.IsActive("50 Skin: Front") = False End If
The doors are made of Skins (front and back of door), Stiles (sides of doors), and Rails (top and bottom of doors)
All Skin Models:
1K
2K
3F (Widths 2-6 to 3-0)
3F (Width 3-6)
3S
50
Issue is.
When I run the 1K rule it works great cuz there's only one 1K model
But for the 3F there's two 3F models that are different sizes.
I need the 3F 3-6 model to be active only if I have the DoorType ="3F" AND the DoorWidthOptions = "3-6"
Then to suppress it if DoorWidthOptions = "3-0", "2-10", "2-8", or "2-6"
This is what I wrote and it doesn't work.
If DoorType = "3F" And DoorWidthOptions = ("2-6" or "2-8" or "2-10" or "3-0") Then Component.IsActive("1K Skin: Back") = False Component.IsActive("1K Skin: Front") = False Component.IsActive("2K Skin: Back") = False Component.IsActive("2K Skin: Front") = False Component.IsActive("3F Skin: Back") = True Component.IsActive("3F Skin: Front") = True Component.IsActive("3F (3-6) Skin: Back") = False Component.IsActive("3F (3-6) Skin: Front") = False Component.IsActive("3S Skin: Back") = False Component.IsActive("3S Skin: Front") = False Component.IsActive("50 Skin: Back") = False Component.IsActive("50 Skin: Front") = False End If
How do I write this to mean if DoorWidthoptions has one selected of a few options so I don't need to write it out for each option
3F and 3-0
3F and 2-10
3F and 2-8
3F and 2-6
How can it be 3F and (3-0, 2-10, 2-8, or 2-6)
