Rule with multiple options
KaynePellegrino
Message 1 of 21
KaynePellegrino
This is a long one.
I make doors. They can be different Widths and Heights, among different Types.
Widths:
3-6 (41.75")
3-0 (35.75")
2-10 (33.75")
2-8 (31.75")
2-6 (29.75")
Heights:
8-0 (95.375")
6-8 (79.375")
Types:
1K (1-Panel)
2K (2-Panel
3F (3-Panel)
3S (3-Panel w/ Glass)
50 (5-Panel)
I have a Width Param & Rule:
DoorWidthOptions [Text, Multi]: 3-6, 3-0, 2-10, 2-8, 2-6
DoorWidth [Num]: (Varies)
Door Width Rule:
'Door Width
If DoorWidthOptions = "3-6" Then
		DoorWidth = 41.75
	End If
If DoorWidthOptions = "3-0" Then
		DoorWidth = 35.75
	End If
If DoorWidthOptions = "2-10" Then
		DoorWidth = 33.75
	End If
If DoorWidthOptions = "2-8" Then
		DoorWidth = 31.75
	End If
If DoorWidthOptions = "2-6" Then
		DoorWidth = 29.75
	End If
I have a Height Param & Rule:
Works same as width, except with the 2 Height options
DoorHeightOptions [Text, Multi]: 8-0, 6-8
DoorHeight [Num]: (Varies)
Door HeightRule:
'Door Height
If DoorHeightOptions = "6-8" Then
		DoorHeight = 79.375
	End If
If DoorHeightOptions = "8-0" Then
		DoorHeight = 95.375
	End If
I have a Door Type Rule: Same rule for all other types as well,  not just '1K'
If DoorType = "1K" Then
		Component.IsActive("1K Skin: Back") = True
		Component.IsActive("1K Skin: Front") = True
		Component.IsActive("2K Skin: Back") = False
		Component.IsActive("2K Skin: Front") = False
		Component.IsActive("3F Skin: Back") = False
		Component.IsActive("3F Skin: Front") = False
		Component.IsActive("3F (3-6) Skin: Back") = False
		Component.IsActive("3F (3-6) Skin: Front") = False
		Component.IsActive("3S Skin: Back") = False
		Component.IsActive("3S Skin: Front") = False
		Component.IsActive("50 Skin: Back") = False
		Component.IsActive("50 Skin: Front") = False
	End If
The doors are made of Skins (front and back of door), Stiles (sides of doors), and Rails (top and bottom of doors)
All Skin Models:
1K
2K
3F (Widths 2-6 to 3-0)
3F (Width 3-6)
3S
50
Issue is.
When I run the 1K rule it works great cuz there's only one 1K model
But for the 3F there's two 3F models that are different sizes.
I need the 3F 3-6 model to be active only if I have the DoorType ="3F" AND the DoorWidthOptions = "3-6"
Then to suppress it if DoorWidthOptions = "3-0", "2-10", "2-8", or "2-6"
This is what I wrote and it doesn't work.
If DoorType = "3F" And DoorWidthOptions = ("2-6" or "2-8" or "2-10" or "3-0") Then
		Component.IsActive("1K Skin: Back") = False
		Component.IsActive("1K Skin: Front") = False
		Component.IsActive("3F Skin: Back") = True
		Component.IsActive("3F Skin: Front") = True
	End If
How do I write this to mean if DoorWidthoptions has one selected of a few options so I don't need to write it out for each option
3F and 3-0
3F and 2-10
3F and 2-8
3F and 2-6
How can it be 3F and (3-0, 2-10, 2-8, or 2-6)
Replies (20)
Message 2 of 21
SMillsYS3X2
For starters consider converting width options to inches and subtracting .25. And the same for door height and subtract 0.625. Numbers is a lot easier than juggling a bunch of string options with long case statements.
Then you can start with making everything inactive and build a If-elseif-end if statement for any variables to turn on each component much easier. Example;
If DoorType = "3F" And DoorWidthO >= 29.75 And DoorWidthO <= 35.75
ElseIf DoorType = "3S" And DoorWidthO >= 29.75 And DoorWidthO <= 35.75
	Component.IsActive("3S Skin: Back") = True
	Component.IsActive("3S Skin: Front") = True
End If
Or better yet use shorter case statements. example;
Select Case DoorType
Case "3F"
	Select Case DoorWidthO
	Case 29.75 To 35.75
	Case 2 To 29.75
		'Etc Etc Etc
	Case Else
		'Etc Etc Etc
	End Select
Case "3S"
	Case 12 To 20
	Case 2 To 12
		'Etc Etc Etc
	End Select
End Select
Message 3 of 21
KaynePellegrino
SMillsYS3X2
The first half is FANTASTIC. That actually is gonna save me so much time and I'm upset I hadn't thought of it sooner.
But the second half, its for "3F Skin" OR "3F (3-6) Skin" that I'm trying to solve
"3F (3-6) Skin" only has 1 model state with a width and height of 3-6 x 8-0
"3F Skin" has multiple widths and heights based on the model state, none of which are 3-6 width
'"3F Skin" Active
If
DoorType = "3F" And DoorWidthOptions = "3-0" Then Component.IsActive("3F Skin: Back") = True Component.IsActive("3F Skin: Front") = True End If If DoorType = "3F" And DoorWidthOptions = "2-10" Then Component.IsActive("3F Skin: Back") = True Component.IsActive("3F Skin: Front") = True End If If DoorType = "3F" And DoorWidthOptions = "2-8" Then Component.IsActive("3F Skin: Back") = True Component.IsActive("3F Skin: Front") = True End If If DoorType = "3F" And DoorWidthOptions = "2-6" Then Component.IsActive("3F Skin: Back") = True Component.IsActive("3F Skin: Front") = True End If
'"3F (3-6) Skin" Active If DoorType = "3F" And DoorWidthOptions = "3-6" Then Component.IsActive("3F (3-6) Skin: Back") = True Component.IsActive("3F (3-6) Skin: Front") = True End If
I need it where the 4 rules in red are one rule
Though I'm presenting one project, knowing how to do that would help with other projects with very similar organization issues.
But, the reason I have the 2 parameters to determine both the height and width of the doors is so the parameters with 'options' in the name can be on the forms I make so they're easier to read/understand by those I share the file with, and so it's faster to change the settings when making new model states. To click a few buttons as opposed to typing in long numbers in multiple boxes.
If doing numbers is easier and or cost less computing power then I'll do that instead, but I really like my forms having the bubbles
Could you explain the 'Case select' stuff a little. I haven't seen that yet but it looks close to what I'm looking for
Message 4 of 21
SMillsYS3X2
Glad that helps. A quick revision of the red section,  assuming you convert DoorWidthOptions to a double variable, I would do something like this -
Dim DoorWidthOptions As Double = '???
Case "3F"
	Select Case DoorWidthOptions
	Case 36
	Case 22
	Case 20
	Case 18
	End Select
End Select
And after looking at that, you could probably just say Case 18 to 36 instead.  🤷‍
Case "3F"
	Case 18 to 36
	End Select
End Select
Case statements are a basic function of visual basic programming. Here is Microsoft's long definition of it -
https://learn.microsoft.com/en-us/dotnet/visual-basic/language-reference/statements/select-case-stat...
EDIT: And sorry, after looking at that. The case statement will only activate if DoorType = "3F"Not if it's value is "3F Skin" or "3F (3-6) Skin", or even "3F ", or "3f". Or to say it another way, the string value must be an exact match. Even capital or lowercase letters and spaces will prevent it from being recognized as a match.
EDIT2: And to get different values for DoorType, and narrow DoorWidthOptionsto specifically to those numbers.... Maybe this is what your looking for?
Case "3F", "3F Skin", "3F (3-6) Skin"
	Case 18, 20, 22, 36
	End Select
End Select
Message 5 of 21
SMillsYS3X2
Message 6 of 21
KaynePellegrino
Oh gosh, I don't know what double variable means either 😅
And I'm not sure the 'case select' stuff is what I need, or if I just don't understand it.
Here's my rule for selecting the Door Type (First part inspired by the code you sent me, makes it much cleaner)
 - Colored it so you can see exactly what parts of the rules are attached to activating which components in the assembly
'Door Type
	End If
If DoorType = "2K" Then
		Component.IsActive("2K Skin: Back") = True
		Component.IsActive("2K Skin: Front") = True
	End If
If DoorType = "3F" And DoorWidthOptions = "3-0" Then
	End If
	End If
	End If
	End If
If DoorType = "3F" And DoorWidthOptions = "3-6" And DoorHeightOptions = "8-0" Then
	End If
If DoorType = "3S" Then
	End If
If DoorType = "50" Then
		Component.IsActive("50 Skin: Back") = True
		Component.IsActive("50 Skin: Front") = True
	End If
The issue is that I have 4 blocks of code to determine if the '3F Skin' component should be active.
The '3F Skin' (not the same as the '3F (3-6) Skin') can be 6-8 or 8-0 tall, and can be 3-0, 2-10, 2-8, or 2-6 wide. So I have multiple model states for the '3F Skin' ipt. for each size it can be.
But the '3F (3-6) Skin' is only 8-0 tall and 3-6 wide. I only have one model state for this ipt.
What I have above works. I just hate that I have to have a different paragraph for each variation for the '3F Skin' with the different widths.
I want to write it like this, where it sees more than one option for the DoorWidthoptions = "__" or "__" or "__". That way I don't have a new paragraph for each combo of the DoorType and DoorWidthOptions parameters.
If DoorType = "3F" And DoorWidthOptions = "3-0" or "2-10" or "2-8" or "2-6" Then
	End If
End If
When the DoorWidthOptions is selected I also have another rule that changes another parameter, "DoorWidth"
When the DoorHeightOptions is selected I also have another rule that changes another parameter, "DoorHeight"
This is the code for it
'Door Height
		DoorHeight = 79.375
	End If
		DoorHeight = 95.375
	End If
'Door Width
		DoorWidth = 41.75
	End If
		DoorWidth = 35.75
	End If
		DoorWidth = 33.75
	End If
		DoorWidth = 31.75
	End If
		DoorWidth = 29.75
	End If
After pasting the last code I think I understood what you were saying with using Numbers instead of 'String options with long case statements'
Would it work better to have the code like this? It works, but just making sure I'm understanding it
'Door Type
	End If
	End If
If DoorType = "3F" And DoorWidth <= 40 Then
	End If
If DoorType = "3F" And DoorWidth >= 40  And DoorHeightOptions = "8-0" Then
	End If
	End If
	End If
I read the 'Case Select' link you sent and I might need to take some sort of basic coding class or watch some videos to understand the terminology better. Like I understand what It's saying and how it connects in the example, I just don't get yet how to use my parameters in that kind of code to get it to work how I need.
Message 7 of 21
KaynePellegrino
Also, here's some pictures so you see what I see
Form in top left of display with all my options
If DoorType = "3F" And DoorWidth >=40 Then
Message 8 of 21
SMillsYS3X2
Yeah, understanding when a variable you are using is a integer, double, string, or boolean and what happens when they are converted to another type is one of the basics of programming. And there is more types, but those 4 are the usual starting point for most people.
Looking at that code, I think you could have a problem with these lines;
	End If
	End If
When DoorType = "3F" and DoorWidth = 40 and DoorHeightOptions = "8-0", you will have all 4 of those components active/on. Why do you keep separating your If - End If statements? Don't want to use If - ElseIf - End If ?
______________
Quick explanation of variable types;
Double are numbers with decimals. Examples - 0.0, 12.347, 0.00415, 128.0
Integer are whole numbers. No decimal or fractions.
String are letters. Even if/when they look like numbers. Need to add " to the beginning and end of string's values.
Boolean are true or false. Yes or no. 0 or 1. It is or is not.
Message 9 of 21
SMillsYS3X2
A quick re-write of the 3F section using if-elseif-endif statement;
If DoorType = "3F" Then
	ElseIf DoorWidthOptions = "2-10" Then
	ElseIf DoorWidthOptions = "2-8" Then
	ElseIf DoorWidthOptions = "2-6" Then
	ElseIf DoorWidthOptions = DoorWidthOptions = "3-6" And DoorHeightOptions = "8-0" Then
	End If
ElseIf DoorType = "X" Then
	'Etc etc etc
ElseIf DoorType = "Y" Then
	'Etc etc etc
ElseIf DoorType = "Z" Then
	'Etc etc etc
End If
Message 10 of 21
KaynePellegrino
Thank you very much for the explanation, it helps a lot!
I'm getting slowly, thank you for being patient
With "Why do you separate...", I honestly didn't realize how to use 'Else' codes. Like I tried it once and couldn't get it, so I forgot about it and wrote all my stuff out; long ways.
But also, I picked 40 knowing that we would never make something that's exactly 40" wide. So i felt it was a safe number. But, curious, would it have been better to write something like:
If DoorType = "3F" And DoorWidth = 35.75, 33.75, 31.75, AndOr 29.75 Then
"Component1" = True
ElseIf DoorWidth = 41.75 Then
"Component2" = True
End If
But I can't find a way to have multiple options in one line. Is there no way to write "one" or "the other" in the same line when saying " If "____" = "
Example: This (With multiple options for the same outcome in one line)
If "Variable1" = "OptionA1" And "Variable2" = "OptionB1" OR "OptionB2" Then '(Multiple Options in the Same Line, separated by some kind of 'or' statement)
		"Component1" = True
Else If "Variable2" = "OptionB3" Then
"Component2" = True End If
 As opposed to how you wrote it (Multiple lines for each combo that equal the same outcome)
	End If
Message 11 of 21
J_Pfeifer_
Slow down, instead of typing everything out manually. Try different things to familiarize yourself with the language.
Sub main()
Dim X as integer = 1
Dim X1 as integer = 2
Dim Y as integer = 3
Dim Y1 as integer = 4
If (x = x1 and y = y1) or y = 4 then
     'do something
Else if X = Y then
     'Do something else
Else
End if
End sub
Not even sure if what I typed above works exactly. However, you can place parentheses within the and side of the or. This will evaluate that section as one of the or's. You can do the same for the other side. Below is a bit of code Ive used.
If (MiddleLetter.StartsWith("D") = True Or MiddleLetter.StartsWith("K") = True) And LastLetter.StartsWith("H") = False Then
				Tank_Leg_Stand_TC = True
			Else
				Tank_Leg_Stand_TC = False
			End If
Message 12 of 21
SMillsYS3X2
Depends on your intent. I didn't know you could write If - ElseIf - End If statements with both those functions and that it would work. I would be careful as I am not a good enough programmer to predict how long single lines like that would work out. And I think the case statements are more clear. I personally would use a lot of brackets (like in a long math equation that has +-* and / in it) just so I know what the order of operations that line would take. Here is the quick experiment I ran to try to figure it out.
Dim A,B,C As String
A = "1"
B = "0"
C = "0"
If A = "1" And (B = "1" Or C = "1")
	MessageBox.Show("1", "Test")
Else
	MessageBox.Show("2", "Test")
end if
Change lines 2 to 4 and see what message shows when it runs, 1 or 2. Change the code on line 6 as well.
EDIT: Just noticed. This is a bad line. The red text should be removed.
Message 13 of 21
J_Pfeifer_
Correct, its all about using the correct tool for the job. Sometimes you need to quickly evaluate a single variable against many different options. This is where I personally use case statements.
Its hard to place into words. I have models that could contain both a "K" or "D" For the middle letter. However the option thats turned on will only apply to those that do not include or have the final letter of the model ID as "H".
KG - true
DG - true
KH - false
DH - False
NG - false
NH - false
This flips on a variable in the back ground that then gets used later. Only specific sets of model ID's actually require this item. However any ID that ends with H physically cannot have the object applied to it at fabrication.
Message 14 of 21
SMillsYS3X2
One more quick note to help - Instead of using a number and checking if it is less than or equal (<=) AND greater than or equal (>=), just use either of those and if it is greater (>) or less than (<). 🤷‍ No overlap of possible values needed.
Message 15 of 21
KaynePellegrino
Thank you!
I think I was able to get it working with the stuff you sent. Still needs some cleaning up, but I'll need to do some studying to do that
Message 16 of 21
J-Camper
@KaynePellegrino ,
I think you just needed to think about the 3F door width options differently.  If you test for negative match first, then you don't need to list out all the other options.  I rewrote the main if statements you had into a select case as it is easier to add more DoorType options later, but try this:
'Door Type
	Case "1K"
	Case "2K"
	Case "3F"
		If DoorWidthOptions <> "3-6"
		Else
			Else
				MessageBox.Show(String.Format("DoorType = {0} | DoorWidthOptions = {1} | DoorHeightOptions = {2}", DoorType, DoorWidthOptions, DoorHeightOptions).ToString, "Un-Accounted For Result:")
			End If
		End If
	Case "3S"
	Case "50"
	Case Else
		MessageBox.Show(String.Format("DoorType = {0}", DoorType).ToString, "Un-Accounted For DoorType:")
End Select
You would need a more complex system if you needed more branches than isolating the 3-6 option from the rest of the width options.  I saw an unfinished branch if you have a 3-6 door width that isn't 8-0 tall, so I added a message in case that ever happens, or you can replace the message with whatever you want to happen in that case.
Let me know if you have any questions
Message 17 of 21
KaynePellegrino
J-Camper
Thank you! This works too. Only part I don't get just from not knowing code very well, how does this work?
Like what does "<>" do exactly
Message 18 of 21
J-Camper
<> means "is not equal to".  Essentially it is the opposite of =.
That line says "If DoorWidthOptions is not set to 3-6, then do this:"  Every option that is not 3-6 will have that group of code to run.  If the option is set to 3-6 then the Else statement after that section will run instead.
Message 19 of 21
Curtis_Waguespack
@KaynePellegrino, I only skimmed through the discussion very quickly, so I might be a bit off base here, but I wanted to add that you can evaluate the condition for true/false, and set the skins to active statuses to be equal or Not equal to that as well. Just another approach, that might reduce the number of lines of code you need to set the IsActive lines.
Hope that helps,
Curtis
This example might or might not be accurate, but should give you an idea of what I am referring to.
Active_Condition = (DoorType = "3F" And (DoorWidthOptions = "2-6" Or DoorWidthOptions = "2-8" Or DoorWidthOptions = "2-10" Or DoorWidthOptions = "3-0"))
Component.IsActive("1K Skin: Back") = Active_Condition
Component.IsActive("1K Skin: Front") = Active_Condition
Component.IsActive("2K Skin: Back") = Not Active_Condition
Component.IsActive("2K Skin: Front") = Not Active_Condition
Component.IsActive("3F Skin: Back") = Not Active_Condition
Component.IsActive("3F Skin: Front") = Not Active_Condition
Component.IsActive("3F (3-6) Skin: Back") = Not Active_Condition
Component.IsActive("3F (3-6) Skin: Front") = Not Active_Condition
Component.IsActive("3S Skin: Back") = Not Active_Condition
Component.IsActive("3S Skin: Front") = Not Active_Condition
Component.IsActive("50 Skin: Back") = Not Active_Condition
Component.IsActive("50 Skin: Front") = Not Active_Condition
Message 20 of 21
KaynePellegrino
J-Camper,
Got it, that's actually super nice to know
