Rule: Iproperties completed before save
I'm looking to help fellow newbies in my department.
I want to have a rule that generates a "pop up" window when Iproperties aren't completed.
This will use the "before save" trigger.
I'm looking to include the following standard Iproperties:
-Part Number
-Stock Number
-Description
-Revision Number
-Project
-Creation Date
-Checked Date
-Eng. Approved Date
I would also like to include the following custom properties:
-Mark
-Remark
Thanks for all the help!
I already have an ilogic form created, if this would be easier to link into the coding.
The form is called "PROPERTIES"
I want to ensure that the entire form is completed before saving the document.
MechMachineMan
Something like this should give you an idea... All you should need to do is add in iProperty checks (and potentially a line to verify what file is being saved if you are planning on using global triggers, instead of Document based triggers)
boolPass = False
count = 0 Do     iLogicVb.ShowForm("Properties")
InventorVb.Update
If iProperties.Value("Project", "Part Number") <> "" And _
iProperties.Value("Project", "Description") <> "" And _
iProperties.Value("Project", "Project") <> "" Then
boolPass = True
Else
MsgBox("Not all properties have been filled in. Save not allowed until all iProps filled in!")
End if
count = count + 1
If count > 10 Then
MsgBox("iProp enforcement failed 10 times. Aborting rule")
Exit Sub
End if
Loop Until boolPass
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Having errors on line 4 & 5 ...
MechMachineMan
That's unfortunate. They can usually be fixed with a bit of googling & some reading.
Justin K
