Rule in Drawing: Need to Copy Selected User Parameter in Derived Part
RoyWickrama_RWEI
Advisor Advisor
RoyWickrama_RWEI
I am trying to get a user parameter copied in to a derived part. I got help from the forum and tailored to my requirement.
https://adndevblog.typepad.com/manufacturing/2012/06/includeexclude-parameters-from-the-base-part-in...
In my rule, I have a problem in the last line.
I Request help.
Sub main()		'Public Sub ModifDerivedParams()
oTDMD = ThisDoc.ModelDocument
	oFFN_TDMD = oTDMD.FullFileName	'Full File Name (ABS)of THMD
	oDN_wExt_TDMD = oTDMD.DisplayName	'Display Name (LFN)of THMD
	'https://adndevblog.typepad.com/manufacturing/2012/06/includeexclude-parameters-from-the-base-part-in-a-derived-part.html
	If oTDMD.DocumentType <> kPartDocumentObject Then
		MsgBox("Make a Part Document the active document")
		Exit Sub
	Else
		MsgBox("This drawig has a part document")
	End If
	If oTDMD.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Count < 1 Then
		MsgBox("No Derived Part Components in this part")
		Exit Sub
	Else
		MsgBox("This part has Derived Part Components")
	End If
	Dim oDPs As New ArrayList()
		For Each oDP In oTDMD.ComponentDefinition.ReferenceComponents.DerivedPartComponents
			MessageBox.Show("oDP: " & oDP.Name, "Title")
			oDPs.Add(oDP)
		Next oDP
	'oDP_Selected = oDerPart.ComponentDefinition.ReferenceComponents.DerivedPartComponents(1)
	oDP_Selected = InputListBox("Prompt", oDPs, oDPs(0), Title := "SELECT DP FROM", ListName := "LIST OF DPs")
	Dim oDerivedPartDef As DerivedPartUniformScaleDef
	oDerivedPartDef = oDP_Selected.Definition
	Dim oDerEntity As DerivedPartEntity
	For Each oDerEntity In oDerivedPartDef.Parameters
		If oDerEntity.ReferencedEntity.Name.Contains("D3") Then
			MessageBox.Show("oDerEntity.ReferencedEntity.Name: " & oDerEntity.ReferencedEntity.Name, "Title")
		oDerEntity.IncludeEntity = True
		End If
	Next
	'To set Definition back, so DerivedPart Document is updated
	oDP_Selected.Definition = oDerivedPartDef
End Sub
HideoYamada
Hello rwickrama,
Try add this line before you use oDP_Selected and your code will work.
Dim oDP_Selected As DerivedPartComponent
And I think it's better to use the option "option Explicit on".
Freeradica
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
RoyWickrama_RWEI
Thanks for the reply. It works.
I also need this to a little bit user friendly (to carry the part name)
Could you help further.  I appreciate your help.
HideoYamada
Hello rwickrama,
I'm not good at iLogic, so there must be more better solution... but I tried.
Replace the code
    oDPs.Add(oDP)
Next oDP
with
Dim derivedPartNameList As New ArrayList()
    derivedPartNameList.Add(oDP.Name)
Next oDP
Dim selectedName As String
selectedName = InputListBox("Prompt", derivedPartNameList, derivedPartNameList(0), Title := "SELECT DP FROM", ListName := "LIST OF DPs")
    If oDP.Name = selectedName Then
        MessageBox.Show("Found : " & selectedName)
        oDP_Selected = oDP
        Exit For
    End If
Next oDP
Best Regards,
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
