RotateSketchObjects not working with INV2023?
h.schkorwaga
Message 1 of 9
h.schkorwaga
Hello together,
since update to latest 2023.2 from 2021 the API method RotateSketchObjects from sketch object does nothing.
The following code wasn't altered for 2 years now and doesn't rotate the textbox anymore.
double dY = Endpoint.Y - Startpoint.Y;
double slope = dY / dX;
double TextboxAlignAngle = dX != 0 ? Math.Atan(slope) : Converter.rad_grd(false) * 90;
ObjectCollection objectCollection = GD.InvAPP.TransientObjects.CreateObjectCollection();
objectCollection.Add(textBoxBend);
sketch.RotateSketchObjects(objectCollection, textBoxBend.Origin, TextboxAlignAngle);
since the preferred approach ...
// Exception  for angles other than 90 and 180°
// textBoxBend.Rotation = TextboxAlignAngle;
... will throw an exception for angles except 0,90,270,360
The above was the way it worked.
Is there another way to rotate textboxes in 2023 API?
Thank you in advance!
BR
Replies (8)
Message 2 of 9
h.schkorwaga
Really no one affected?
Message 3 of 9
h.schkorwaga
No?
Message 4 of 9
h.schkorwaga
Message 5 of 9
florian_wenzel
what is in your ObjColl ?
i do something like this:
First i show the Boudaries fromTextBox
  Dim oTextBox As TextBox = oSketchTextBox.TextBoxes.AddFitted(oText_Point, oStringTextBox)
            oTextBox.ShowBoundaries = True
Next, then Get each SketchLine from BoundariesTextBox
      Dim oSketchLine As SketchLine
        Dim oObjColl As ObjectCollection = oTO.CreateObjectCollection
        For i = 1 To oSketch.SketchLines.Count
            oSketchLine = oSketch.SketchLines.Item(1)
            oObjColl.Add(oSketchLine)
        Next
Next,  i Rotate the ObjColl
    oSketch.RotateSketchObjects(oObjColl, oPoint, oAngle_Corection)
In this Case is VB.NET
But i want to say, that i Rotate the Boudaries of TextBox, not only the TextBox
Message 6 of 9
h.schkorwaga
Hi Florian,
thank for this good hint - but it unfortunately doesn't work for me.
ShowBoundaries is true (since years 🙂 )
With c# I did this now:
foreach (SketchEntity item in textBoxBend.BoundaryGeometry)
    objectCollection.Add((SketchLine)item);
As in the sketch are more than one TextBoxes and other SketchLines I had a look in the API-Help. There I found the BoundaryGeometry which should return me the four border sketchlines of the textbox. The cast to SketchLine was my last hope, and shouldn't be necessary I guess.
May you could make a fast try if this works for you? If not then I suppose API is buggy here and I have to find another way to get this four SketchLines.
Message 7 of 9
florian_wenzel
hi,
small change
Take only the First (1)  SketchLine from TextBox BoundaryGeometry.    - Not each
Next, take a MidPoint of this Line.
And Rotate this through this Point
I Have Still  Inventor 2022, too lazy.
Message 8 of 9
florian_wenzel
C# Code:
it Works with Inventor 2023 latest Updates.
Update: With SketchLines only from TextBox
Message 9 of 9
h.schkorwaga
Hi again,
thank you for your efforts. My whole code was not so far away from yours. Despite I tried to take yours which led me to the same result. BUT was I just saw when swithing to Flatpattern in inventor was that the boundary was very small after rotating the textbox. When doing a resize manually with the mouse the text flips and is displayed with 90deg (see video attached).
Conclusion:
My code that worked for years worked the whole time (no need to rotate a boundary sketchline just the textbox itself) - BUT the behaviour of the boundary (or textbox) changed. I just haven't recognized this circumstance.
So, after rotating I adjusted the height of the textbox (simply double the fontsize)
textBoxBend.Height = fontsize*2;
This worked for me now!
Thank you very much!
Hel
