Message 1 of 9
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello together,
since update to latest 2023.2 from 2021 the API method RotateSketchObjects from sketch object does nothing.
The following code wasn't altered for 2 years now and doesn't rotate the textbox anymore.
double dY = Endpoint.Y - Startpoint.Y;
double slope = dY / dX;
double TextboxAlignAngle = dX != 0 ? Math.Atan(slope) : Converter.rad_grd(false) * 90;
ObjectCollection objectCollection = GD.InvAPP.TransientObjects.CreateObjectCollection();
objectCollection.Add(textBoxBend);
sketch.RotateSketchObjects(objectCollection, textBoxBend.Origin, TextboxAlignAngle);
since the preferred approach ...
// Exception for angles other than 90 and 180°
// textBoxBend.Rotation = TextboxAlignAngle;
... will throw an exception for angles except 0,90,270,360
The above was the way it worked.
Is there another way to rotate textboxes in 2023 API?
Thank you in advance!
BR
