Reusing iMates
Reusing iMates
Reusing iMates
I need to reuse some iMates and would like some advice about how to code this.
Background Information
I will be constraining parts/assemblies to an extruded aluminum beam.
This beam has 4 slots and thus four composite iMates.
This is a simplified shaft clamp and it has 2 similar composite iMates that mate to any slot on the beam. There are 2 to allow me to flip the clamp over. (We have lots of different clamps so that is necessary). There are also other iMates on it that are important
Part 1
First, I ALT+drag-and-drop the composite iMates to the slot I want:
Next, I want the code to reapply the iMates within the composite iMate and then delete the composite iMate so it looks like this:
It should be noted that I mated the iMates of the under the Clamp's composite iMate with the Beam's original geometry that the iMates referenced, not the iMates themselves as you can't do that.
The reason for this is so that I can reuse the Composite if I want to change the location on the beam.
Part 2
I want to be able to change the location of the clamp a different slot by ALT+dragging the composite iMate. Thus, I need the code to delete the previous iMates and then repeat part 1.
Problem
When you ALT+drag a composite iMate over another, before releasing the mouse, Inventor fires a new relationship event (in code) to visualize what will happen. Thus, if you ALT+drag a composite over another composite, drag it away, and then bring it back, it fires a new relationship event multiple times in the AssemblyEvents_OnNewRelationship. This is a problem because I was thinking of using that event to add iMates and then delete the Composite. Or can I still do that anyway?
In other words, I am wondering if anyone has advice or some pseudocode about the best way to implement this idea. I was thinking about handling the assembly Events to do it but not sure if this is best. If all else fails, I can have multiple commands that I manually fire but this is less than optimal. Also, do you think it would be possible to have the code change the Position representation of the clamps depending on which iMate I grab?
Thank you
Let me know if this is confusing and you need me to clear anything up. Attached should be the parts but here is an extra link for more convenience.
https://drive.google.com/file/d/1LmP9PrehjmeN_VYk9bez1FcVMk-M_8Vb/view?usp=sharing
HermJan.Otterman
so in short? you have 4 places that you want to be able to place some component (A)?
all 4 places must have the same iMate composite and also the component (A).
the create a new empty component (E) that has only the imate composite.
in your assembly place on all four places the (dummy) empty component (E)
than with code you can use replace to change Component (A) for Component (E) 1, 2, 3 or 4..
I hope you can follow...
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
I got the general concept working and I still need to do some modifying but here is the code so far. Fair warning, I got my degree in Mechanical Engineering, not Computer science. The code is very sloppy and there is no documentation.... yet. To get it to work you need to change the iComposite name to "Regular" or "Flipped." I still need the code to change the Position Rep depending on which iComposite you grab and I need to be able to make it work on mutiple Composites.
Here is the module.
Public oCustomCommand As class1
Sub starting()
    Set oCustomCommand = New class1
End Sub
And the class
Private WithEvents oAssemblyEvents As AssemblyEvents
Private WithEvents oDocEvents As DocumentEvents
Private WithEvents oTrans As TransactionEvents
Private A1 As iMateResult
Private oCommit As Boolean
Private oAbort As Boolean
Private DeleteConstraints As Boolean
Private la As Transaction
Private Sub Class_Initialize()
    Set oAssemblyEvents = ThisApplication.AssemblyEvents
    Set oDocEvents = ThisDocument.DocumentEvents
    oCommit = False
    oAbort = False
    DeleteConstraints = False
End Sub
Private Sub Class_Terminate()
    Set oAssemblyEvents = Nothing
    Set oBrows = Nothing
    Set oUser = Nothing
End Sub
Private Sub oAssemblyEvents_OnNewRelationship(ByVal DocumentObject As AssemblyDocument, _
    ByVal Relationship As Object, ByVal BeforeOrAfter As EventTimingEnum, _
    ByVal Context As NameValueMap, HandlingCode As HandlingCodeEnum)
    If BeforeOrAfter = kAfter Then
        'On Error GoTo 1:
        ' Check if it is a composite
        If Relationship.Type = kiMateResultObject Then
            If Relationship.IsComposite = True Then
                Dim oAttribSet As AttributeSet
                Dim oCon As AssemblyConstraint
                Dim oRelationship As iMateResult
                Set oRelationship = Relationship
                Debug.Print "test"
                ' If it is a composite then start up the transaction manager to
                '       monitor when it is done
                If oTrans Is Nothing Then
                    Set oTrans = ThisApplication.TransactionManager.TransactionEvents
                End If
                ' The iMate has been chosen
                If oCommit = True Then
                    oCommit = False
                    Set oTrans = Nothing
                    Dim oP As MateConstraint
                    Set oP = oRelationship.Constraints(1)
                    For Each iMateDef In oP.AffectedOccurrenceOne.iMateDefinitions
                        oCompositeName = iMateDef.Name
                        If (iMateDef.Name = "Regular") Or (iMateDef.Name = "Flipped") Then
                            Set oEntityCompare1 = iMateDef.Item(1).Entity
                            Set oEntityCompare2 = iMateDef.Item(2).Entity
                            If oEntityCompare1 Is oP.EntityOne Then
                                If oEntityCompare2 Is oRelationship.Constraints(2).EntityOne Then
                                    Set iMate1 = iMateDef.Item(1)
                                    Set oEntity1 = oRelationship.Constraints(1).EntityTwo
                                    Set iMate2 = iMateDef.Item(2)
                                    Set oEntity2 = oRelationship.Constraints(2).EntityTwo
                                End If
                            End If
                        End If
                    Next
                    Set oOcc = oRelationship.Constraints(1).AffectedOccurrenceOne
                    Dim oConstraints As AssemblyConstraintsEnumerator
                    Call ThisApplication.TransactionManager.UndoTransaction
                    Dim oDef As AssemblyComponentDefinition
                    Set oDef = ThisDocument.ComponentDefinition
                    Dim oTxn As Transaction
                    Set oTxn = ThisApplication.TransactionManager.StartTransaction(ThisApplication.ActiveDocument, "Custom")
                    Set oConstraints = oOcc.Constraints
                    If DeleteConstraints = True Then
                        For Each oCon In oConstraints
                            If Not oCon.iMateResult Is Nothing Then
                                For Each oAttribSet In oCon.iMateResult.AttributeSets
                                    If oAttribSet.Name = "Attachment" Then
                                        Call oCon.Delete
                                    End If
                                Next
                            End If
                        Next
                    End If
                    Dim Zup As iMateResult
                    Dim Yup As iMateResult
                    Set Zup = oDef.iMateResults.AddByiMateAndEntity(iMate1, oEntity1)
                    Set Yup = oDef.iMateResults.AddByiMateAndEntity(iMate2, oEntity2)
                    ' Mark the new mates
                    Dim oAttribSets As AttributeSets
                    Call Zup.AttributeSets.Add("Attachment")
                    Call Yup.AttributeSets.Add("Attachment")
                    oTxn.End
                ' It's trying to be applied so look to see if constraints are
                '   already there to be suppressed
                ElseIf oCommit = False Then
                    Dim oRunning As Boolean
                    oRunning = False
                    For Each oCon In oRelationship.Constraints(1).AffectedOccurrenceOne.Constraints
                                    If oRunning = False Then
                                        oRunning = True
                                        Dim oSuppressTxn As Transaction
                                        Set oSuppressTxn = ThisApplication.TransactionManager.StartTransaction(ThisApplication.ActiveDocument, "Supress custom constraints")
                                        Set la = oSuppressTxn
                                    End If
                                    Call oCon.Delete
                                End If
                            Next
                        End If
                    Next
                    If oRunning = True Then
                        oRunning = False
                        oSuppressTxn.End
                    End If
                End If
            End If
        End If
1:
            On Error GoTo 0
    End If
End Sub
Private Sub oTrans_OnAbort(ByVal TransactionObject As Transaction, ByVal Context As NameValueMap, ByVal BeforeOrAfter As EventTimingEnum)
    'If the operation is aborted, stop monitoring the undo so you don't
    '   accidentally catch something else
End Sub
Private Sub oTrans_OnCommit(ByVal TransactionObject As Transaction, ByVal Context As NameValueMap, ByVal BeforeOrAfter As EventTimingEnum, HandlingCode As HandlingCodeEnum)
Debug.Print "OnCommit"
oCommit = True
End Sub
