Retrieve the parent file name of an ipart member
keithjk
keithjk
This should be easy but I am having trouble figuring it out.
I need to get the filename of the ifactory parent file for a given ipart member.  I need it work for both .ipt and .iam iparts.
Below is a start on my code.  The section I need help with is underlined in red.
Private Sub TestThis ()
 Dim oDocPart As PartDocument = Nothing
 Dim oDocAssembly As AssemblyDocument = Nothing
 If oInventorApp.ActiveDocument.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
    oDocPart = oInventorApp.ActiveDocument
  Debug.Print("This is a part document. The filename is:" & oDocPart.FullDocumentName)
  If oDocPart.ComponentDefinition.IsiPartMember Then
   'get the file name of the parent part (that contains the iPart table)
  ElseIf oInventorApp.ActiveDocument.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
     oDocAssembly = oInventorApp.ActiveDocument
  If oDocAssembly.ComponentDefinition.IsiAssemblyMember Then
  Else
  'not and .ipt or .iam so exit
   Exit Sub
End Sub
HermJan.Otterman
Hello Keith,
here is your code....
Private Sub TestThis()
Dim oDoc As Inventor.Document = _inventorApplication.ActiveDocument
If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
Dim oPartDoc As PartDocument = TryCast(oDoc, PartDocument)
If oPartDoc.ComponentDefinition.IsiPartMember = True Then
Dim ParentName As String = oPartDoc.ReferencedDocumentDescriptors(1).DisplayName
MsgBox(ParentName)
ElseIf oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
Dim oAssyDoc As AssemblyDocument = TryCast(oDoc, AssemblyDocument)
If oAssyDoc.ComponentDefinition.IsiAssemblyMember = True Then
Dim ParentName As String = oAssyDoc.ReferencedDocumentDescriptors(1).DisplayName
MsgBox(ParentName)
Else
Exit Sub
End Sub
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Perfect!
Thank you!
HermJan.Otterman
great that is works...
would you kindly please choose "exept as solution"
so others can see that there is a solution,
and I get my satisfaction Smiley Happy
thanks
Herm Jan
danielvdeleito
Simple way how to get the filename of an occurrence by position in the tree:
oDoc = ThisDoc.Document
oOccs = oDoc.ComponentDefinition.Occurrences
Dim occ As ComponentOccurrence
occ = oOccs.Item(1)'this is the occurrence number
Dim memberDoc As PartDocument
memberDoc = occ.Definition.Document
Dim factoryDoc As PartDocument
factoryDoc = memberDoc.ComponentDefinition.iPartMember.ReferencedDocumentDescriptor.ReferencedDocument
ParentName = factoryDoc.DisplayName
