iLogic Expose "Thickness" to custom iProperty
chrisw01a
chrisw01a
Ok.  I give up.
This should be simple.
Just need to flag the sheetmetal "Thickness" parameter for export, then create a custom iProp called "Thickness" and assign its value to sheetmetal Thickness.
What am I doing wrong here?
Keep getting this message :
Error in rule: ASY Total Part QTY, in document: 82387-070.iam
Public member 'Parameter' on type 'SheetMetalComponentDefinition' not found.
'Set a reference to the primary ComponentDefinition of the row
	Dim oCompDef As ComponentDefinition = oBOMRowPO.ComponentDefinitions.Item(1)
	'Check if the component is supressed
	'If oCompDef.Suppressed = False Then
		'get the full filename associated to the component in the row. ex: c:\temp\part1.ipt
		Dim CompFullDocumentName As String = oCompDef.Document.FullDocumentName
		Dim CompFileNameOnly As String
		'get the location of the last backslash
		Dim index As Integer = CompFullDocumentName.lastindexof("\")
		'get the filename only from the full filename
		CompFileNameOnly = CompFullDocumentName.substring(index+1)
		'MessageBox.Show(CompFileNameOnly)
		'get the Qty value in the current row
		Dim Qty As String = oBOMRowPO.TotalQuantity
		'check to see if the component is a library part, cc part or read only.
		Dim IsLibCCReadonly As Boolean = LibCCReadonlyChecker(CompFullDocumentName)
			'if the file is NOT a library part, cc part or read only.
			If IsLibCCReadonly = False Then
			'set following custom iproperty to equal the QTY from the row
			iProperties.Value(CompFileNameOnly, "Custom", "TotalPartQty") = Qty
				' Look at the sheet metal parts only
				'If oDoc.DocumentSubType.DocumentSubTypeID <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then Continue For
				Dim oParam As Inventor.Parameter = oCompDef.Parameters.Item("Thickness")
				If oParam IsNot Nothing Then
				'Flag to export
				oParam.ExposedAsProperty = True
'Problem happens is HERE ....... iProperties.Value(CompFileNameOnly, "Custom", "Thickness") = oCompDef.Parameter("Thickness")
Thank you guys
HermJan.Otterman
Hello Chris,
first, for the future, turn on the checkbox in your sheetmetal template.......
Here is some (VB.net) code... (What are you using?)
Private Sub TurnOnThicknessExport()
Dim oAssyDoc As AssemblyDocument = _inventorApplication.ActiveDocument
Dim oDoc As Inventor.Document
For Each oDoc In oAssyDoc.AllReferencedDocuments
If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
Dim oPartDoc As PartDocument = TryCast(oDoc, PartDocument)
If oPartDoc.ComponentDefinition.Type = ObjectTypeEnum.kSheetMetalComponentDefinitionObject Then
Dim oParam As Inventor.Parameter = GetParameterByName(oPartDoc, "Thickness")
Next
End Sub
Private Function GetParameterByName(ByVal oPartDoc As Inventor.PartDocument, ByVal ParmName As String) As Inventor.Parameter
Dim oParam As Inventor.Parameter = Nothing
Dim oParamFound As Boolean = False
For Each oParam In oPartDoc.ComponentDefinition.Parameters
If oParam.Name = ParmName Then
oParamFound = True
Exit For
Next
If oParamFound = False Then oParam = Nothing
Return oParam
End Function
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
b_sharanraj
I didn't execute you code still i see this should be corrected as
iProperties.Value(CompFileNameOnly, "Custom", "Thickness") = oCompDef.Parameters.Item("Thickness").Value
Regards
B.Sharan Raj
HermJan.Otterman
maybe you should execute the code....!?
if you check the export check box, there will be automatically a property with the name and value.
so I don't see what you code is doing...
Herm Jan
chrisw01a
Lol.  I was trying to overcomplicate it.
Thank you.
Chris
mikejones
Hi @HermJan.Otterman
Is there any chance of writing that in iLogic  instead of VBA?
Mike
Autodesk Certified Professional
HermJan.Otterman
Hello Mike,
just copy paste all code in an iLogic rule,  then only change the first two lines:
Private Sub Main()
Dim oAssyDoc As AssemblyDocument = ThisDoc.Document
the first sub sould be called "Main"
then, to get the document, use the iLogic code for this: ThisDoc.Document
now it should work
Herm Jan
