- Mute
- Permalink
- Report
This should be easy but I am having trouble figuring it out.
I need to get the filename of the ifactory parent file for a given ipart member. I need it work for both .ipt and .iam iparts.
Below is a start on my code. The section I need help with is underlined in red.
Private Sub TestThis ()
Dim oDocPart As PartDocument = Nothing
Dim oDocAssembly As AssemblyDocument = Nothing
If oInventorApp.ActiveDocument.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
oDocPart = oInventorApp.ActiveDocument
Debug.Print("This is a part document. The filename is:" & oDocPart.FullDocumentName)
If oDocPart.ComponentDefinition.IsiPartMember Then
'get the file name of the parent part (that contains the iPart table)
ElseIf oInventorApp.ActiveDocument.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
oDocAssembly = oInventorApp.ActiveDocument
If oDocAssembly.ComponentDefinition.IsiAssemblyMember Then
Else
'not and .ipt or .iam so exit
Exit Sub
End If
End If
End If
End Sub
