Hi @sschulteH6WZ3
Here is an iLogic rule that I had on hand or this... it has a few options built in that might fit your needs, but if you need help modifying it further, you might start a new thread on the Inventor Customization forum with some details and/or examples.
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
Sub Main()
Logger.Info(" ")
Logger.Info("RuleName: " & iLogicVb.RuleName)
'Re-numbers all view labels on all sheets
' handles aplha or numeric
' option to set all to aplha
' option to set all to Numeric
' option to set only details and sections to alpha
oScheme = "Numeric w/ details and sections as Alpha"
'oScheme = "All Numeric"
'oScheme = "All Alpha"
Dim oDoc As DrawingDocument
Dim oSheet As Sheet
Dim oView As DrawingView
'check if active document is a drawing
If ThisApplication.ActiveDocument.DocumentType <> kDrawingDocumentObject Then
Exit Sub
End If
oDoc = ThisApplication.ActiveDocument
i = 9
k = 1
'Rename view identifiers
'look at all sheets
For Each oSheet In oDoc.Sheets
'look at all views on sheet
For Each oView In oSheet.DrawingViews
'renumber only detail and section
If oScheme = "All Numeric" Then
oView.Name = i
i = i + 1
ElseIf oScheme = "All Alpha" Then
oView.Name = num2Letter(i)
i = i + 1
Else If oScheme = "Numeric w/ details and sections as Alpha" Then
If oView.ViewType = DrawingViewTypeEnum.kSectionDrawingViewType Or _
oView.ViewType = DrawingViewTypeEnum.kDetailDrawingViewType Then
'skip I, O, & Q
If InStr(1, num2Letter(i), "I") > 0 Or _
InStr(1, num2Letter(i), "O") > 0 Or _
InStr(1, num2Letter(i), "Q") > 0 Then
i = i + 1
End If
i = i + 1
Else
oView.Name = k
k = k + 1
End If
End If
Next oView
Next oSheet
End Sub
Public Function num2Letter(num As Long) As String
'converts long to corresponding alpha
'Ex. 1 = A, 28 = AB
remain = num Mod 26
whole = Fix(num / 26)
If num < 27 Then
If remain = 0 Then
num2Letter = "Z"
Else
num2Letter = Chr(remain + 64)
End If
Else
If remain = 0 Then
num2Letter = Chr(whole + 63) & "Z"
Else
num2Letter = Chr(whole + 64) & Chr(remain + 64)
End If
End If
End Function
