iLogic - Export Weldment as .stl file with welds included
tallen7EJGU
tallen7EJGU
I'm working on an iLogic rule to export a weldment (.iam) to an .stl format file. This type of rule has worked well in the past for exporting .step files, but I've noticed that when run for a .stl file, the welds aren't present in the .stl file.
Note - no error codes are generated and the .stl file is exported correctly other than the welds missing.
Code is attached below - I haven't had a chance to clean it up so it's a bit messy (my apologies) - Line 39 is performing the physical .stl save function.
cidhelp
Hi @tallen7EJGU ,
if you use STL TranslatorAddIn with option "Resolution"=1 ("Resolution"=4 seams without welds) the STLfile includes welds.
I changed the export path (C:\Temp\Test in my case) and STL is only exported for iam files.
