How To Delete Occurrence Pattern Element
tim11_manhhieu
tim11_manhhieu
I want to delete the OIL OUTLET object as shown in the picture but when running the code, it gives an error at the line occPatternElem.occurrences.item(i).Delete2 (False)
Need expert help or is there another way, iLogic or VBA is fine.
Option Explicit
Sub SuppressPatternOccurrencesByName()
    Dim asmDoc As AssemblyDocument
    Dim asmDef As AssemblyComponentDefinition
    Dim occPattern As OccurrencePattern
    Dim targetName As String
    Dim i As Integer
    Dim rectPattern As RectangularOccurrencePattern
    Dim circPattern As CircularOccurrencePattern
    Dim compOcc As ComponentOccurrence
    Dim occPatternElem As OccurrencePatternElement
    targetName = "OIL OUTLET"
    Set asmDoc = ThisApplication.ActiveDocument
    If asmDoc.DocumentType <> kAssemblyDocumentObject Then
        MsgBox "Please open an Assembly file before running this macro!", vbExclamation
        Exit Sub
    Set asmDef = asmDoc.ComponentDefinition
    For Each occPattern In asmDef.OccurrencePatterns
        If TypeOf occPattern Is RectangularOccurrencePattern Then
            Set rectPattern = occPattern
            For Each occPatternElem In rectPattern.OccurrencePatternElements
                For i = occPatternElem.occurrences.count To 1 Step -1
                    If InStr(1, occPatternElem.occurrences.item(i).name, targetName, vbTextCompare) <> 0 Then
                Next i
            Next occPatternElem
    Next occPattern
End Sub
JLH_Bigadan
You can’t delete pattern members directly with Delete2, since they belong to the pattern definition. Instead, you need to suppress the occurrence. Try replacing the Delete2 call with:
occPatternElem.Occurrences.Item(i).Suppressed = True
tim11_manhhieu
thank you for reply.
Andrii_Humeniuk
Hi @tim11_manhhieu.
As @JLH_Bigadan  wrote earlier, it is not possible remove the component from PatternElements, but this can be done at the OccurrencePattern level for all PatternElements. This is done by re-saving the ObjectCollection. Example iLogic code:
Sub main()
    Dim asmDoc As AssemblyDocument = ThisApplication.ActiveDocument
    Dim asmDef As AssemblyComponentDefinition = asmDoc.ComponentDefinition
        MsgBox("Please open an Assembly file before running this macro!", vbExclamation)
        Exit Sub
			Dim i As Integer = 0
			For k As Integer = 1 To rectPattern.ParentComponents.Count
				If rectPattern.ParentComponents(k).Name.Contains(targetName) Then
					i = k
					Exit For
			Next k
			If i = 0 Then Continue For
			Dim oObjs As ObjectCollection
			oObjs = ThisApplication.TransientObjects.CreateObjectCollection(rectPattern.ParentComponents)
            oObjs.Remove(i)
			rectPattern.ParentComponents = oObjs
    Next occPattern
End Sub
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
tim11_manhhieu
Many thanks.
