Reset multivalue parameters in a form
jeremiah_boe
jeremiah_boe
I currently have code that adjusts the multi-value parameter, for form use, based upon other parameters being selected. By default when I open the form I would like all of the multi-value lists to read "Product Specific" as the value. I am looking for a way to have the form forget the previous selected values when opened and go back to the "Product Specific" value.
WCrihfield
There's likely two options to do this.
  1. What ever is firing your Form to open, have it also run an external rule, hopefully right before it launches the form that resets all of those MultiValue Parameters back where you want them.
  2. You will have to use (or create, then use) a local rule with an Event watcher, that will reset those parameters.
Wesley Crihfield
(Not an Autodesk Employee)
