in the ContourRollFeature i did not see anything about the values that you are looking for. i dont think that there is a direct way to do this. But you can isolate the ContourRollFeature and then get the flatpattern length. try this:
Dim doc As PartDocument = ThisApplication.ActiveDocument
Dim docDef As SheetMetalComponentDefinition = doc.ComponentDefinition
Dim features As SheetMetalFeatures = docDef.Features
Dim roll As ContourRollFeature = features.ContourRollFeatures.Item(1)
' suppress all feature except the ContourRollFeature
For Each f As PartFeature In features
If (f.Name.Equals(roll.Name) = False) Then
f.Suppressed = True
Next
If (docDef.HasFlatPattern = False) Then
docDef.Unfold()
docDef.FlatPattern.ExitEdit()
Dim length As Double = docDef.FlatPattern.Length * 10
Dim width As Double = docDef.FlatPattern.Width * 10
' unsuppress all features
f.Suppressed = False
Next
MsgBox(length & "mm x " & width & "mm")
Jelte de Jong
Blog: hjalte.nl - github.com
