Override DisabledCommandTypes
LarsBJepsen
LarsBJepsen
I have this code which disables all Commands that can affect the geometry of the model, including running macros. I would like to be able to run macros while all other commands are disabled, so the question is if there is any way to override the disabledcommandtypes to enable running of macros while all other commands in "kEditMaskCmdType" are disabled?
/Lars
Sub Noneditble()
Dim oDoc As Document
Set oDoc = ThisApplication.activedocument
oDoc.DisabledCommandTypes = kEditMaskCmdType
End Sub
LarsBJepsen
I have the code below, that should do some of what I Want, but it's not working - i get an error at line13 (oDoc.DisabledCommandList.Remove (oPrintCmd)). oDoc.DisabledCommandTypes = 4 ,disables file operations like save and print, and then i try to enable the print command again.
Sub ReadOnly()
Set oDoc = ThisApplication.ActiveDocument
Dim oPrintCmd As ControlDefinition
Set oPrintCmd = ThisApplication.CommandManager.ControlDefinitions.Item("AppFilePrintCmd")
End Sub
LarsBJepsen
One step closer, but still not enabling the print command.
Sub test()
Dim controlDef As ControlDefinition
    For Each controlDef In ThisApplication.CommandManager.ControlDefinitions
        If (controlDef.InternalName = "AppFilePrintCmd") Then
            If controlDef.Enabled = False Then
                controlDef.Enabled = True
            Exit For
 Next
End Sub
