Reset application options
Can someone explain the intended behavior for "Use Inventor Settings." From the Help File I found this which I don't understand.
Import and export of application options
If you import a set of default application options to switch the default option set after your initial setup, you change only the settings that differ between the two. The import process does not alter any other Application Options settings that you changed.
I understand that if you want to reset the application options you'll need to delete/rename some registry keys. However, I want to understand how Applicaton Options > Import... > Use Inventor Settings works.
Settings such as Application Options > Colors > Background do not change, whereas the Color Scheme will change back to Winter Night.
What is the deal?
