Difference between Coincident GeometricConstraint and Merge
danijel.radenkovic
danijel.radenkovic
Hello Everyone,
  1. Can someone explain me the difference between Coincident GeometricConstraint and Merge?
  2. Also I would like to know what is a practice that you folow while you create a circle which is conected with other two (already created) by their Start/End Points (See attached image). I am asking cause sometimes using method "Three Point Arc" it is very difficult to define third point of middle arc. Did you create first arc somewere in the 2D space and then with applying a constraints you get the results like on the attached image.
Regards
Danijel
Inventor 2018/Windows 10 x64
If this information was helpful, please consider marking it as an Accepted Solution by using the Accept as Solution. Kudos are also gladly accepted.
danijel.radenkovic
Does anybody know?
