I Logic to set part numbers.
I have a something strange hapening here. I have created a part that adjusts to design and under cenrtn conditions we have partnumbers that i would like to reflect in the stock number property. I have writen the ilogic code to do just htat but for some reason when i asign a paramitor to 30 deg it will not work properly.
SyntaxEditor Code Snippet
MessageBox.Show(InclienAngle, "InclienAngle")
MessageBox.Show(NoseOver, "NoseOver")
PlateAngle = InclienAngle + NoseOver
MessageBox.Show(PlateAngle, "PlateAngle")
'MessageBox.Show(PlateAngle, "PlateAngle")
If Length = 119 Then
    PNumber = "Skirt Plate B"
Else
    PNumber = "Skirt Plate A"
If Pitch = 9 Then
    Select Case Floor(PlateAngle)
        Case = 30
            ShopRef = "SR2000309, " + PNumber
            MessageBox.Show(ShopRef, "PlateAngle")
        Case = 32
            ShopRef = "SR2000801, " + PNumber
        Case = 35
            ShopRef = "SR2000310, " + PNumber
        Case = 40
            ShopRef = "SR2000311, " + PNumber
        Case = 45
            ShopRef = "SR2000312, " + PNumber
    End Select
iProperties.Value("Project", "Stock Number") = ShopRef
iProperties.Value("Project", "Part Number") = PNumber
I have added the messagebox to help troubleshoot. but it works on 32, 35, 40, and 45deg but the 30 does not work. I don't see any reason this would not work but for some reason it does not seam to read the Case = 30 lines.
smilinger
My guess, it is something about precision.
Somehow your PlateAngle may be 29.999999999, so Floor(PlateAngle) = 29.
Try use PlateAngle = Round(PlateAngle, 7) before comparison.
Just my guess.
