Reset application options
mkoenig1
mkoenig1
Can someone explain the intended behavior for "Use Inventor Settings."  From the Help File I found this which I don't understand.
Import and export of application options
If you import a set of default application options to switch the default option set after your initial setup, you change only the settings that differ between the two. The import process does not alter any other Application Options settings that you changed.
I understand that if you want to reset the application options you'll need to delete/rename some registry keys.  However, I want to understand how Applicaton Options > Import... > Use Inventor Settings works.
Settings such as Application Options > Colors > Background do not change, whereas the Color Scheme will change back to Winter Night.
What is the deal?
k14348
you made some customizaton in application settings and saved with different name as xml Document. If you are going to change your system that time you can export your settings as xml document and copy this file to your new system. Now you can open inventor in new system and import that file.  So that you dont need to make settings everytime unnecessarily. It will save time also.
-karthikeyan
