Replacing parts list column by the name of its corresponding property
Hi
I'm trying to convert an existing parts list to use a new column.
Knowing just the name of the iProperty whose the corresponds to the column (not the title that's displayed in the table), how can I identify and remove this column, and put another in its place?
bradeneuropeArthur
Do you have an example template and what column do you like to remove and add and whit which iproperty?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Sorry for the slow response.
It's a custom iProperty. I'm just looking to remove a column and insert another in its place, that's all.
A.Acheson
Here is the API sample to work with the Partslist written in vba launguage. Hopefully that gets you moving in the right direction. If you need to use ilogic then do the conversion of the code. Main changes for that are to remove the sub routine header and footer and remove the word Set.
Remove a column
Syntax
PartsListColumn.Remove()
Add a column
Syntax
PartsListColumns.AddPropertyType As PropertyTypeEnum, [PropertySetId] As String, [PropertyIdentifier] As Variant, [TargetIndex] As Long, [InsertBefore] As Boolean ) As PartsListColumn
Regards
Alan
