replacing all assembly & file refs
NachoShaw
Advisor Advisor
NachoShaw
Hey
ive got an issue thats perplexing me and to be honest, i thought it would be easier than it is..
i have an assembly that isnt very well designed. Id like to replace it but there is a lot of other legacy automation involved i just cant right now. anyway, updating the code to add a job number to the prefix (as the jobs were being saved in projects with generic file names) has meant a re-write of a lot of code and its this that i cant seem to get right.
What i need to do
Loop through the top level assembly documents as reference files, add the prefix to the document filename and save it in a new location. Then, change the reference in the assembly to the new component. Reloop if the referenced document is also an assembly.
The problem im getting is linked base models. They dont seem to change and for every document i replace, i also need to update these referenced documents too. So, is there any code out there that can help me-
copy the top level assembly to a new folder
copy all of the assembly references to the same folder
if the reference is also an assembly, copy that and all of its child docs
replace all references including any documents that a linked or derived in parts / assembles
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Michael.Navara
If it is single task, which will not be repeated, use DesignAssistant or Vault. For single copy it is the quickest way.
NachoShaw
Hi
It's not a single task I'm afraid.. it's before my time as VBA but it's a dependency tool for about 10 users who use it multiple times per day.
Nacho
Michael.Navara
In this case Vault CopyDesign functionality is suitable for this task. If you are looking for some programming solution, I recommend you to use ApprenticeServer. It is the best tool for copying Inventor documents.
Few years ago I made very similar tool for copying complex assemblies and its parts, but it wasn't an easy task and it spends a lot of time.
NachoShaw
Hey
I too made an apprentice tool and it's fast however.... this particular code set is VBA and can't use apprentice. We want to transition to vault but we're not there yet.
Unfortunately that was all together before my time and it's hard to change minds to get investment for updates..
I want to make a new model, this one has 7 base models for an assembly that has 8 unique parts in 150 occurrences
Nacho
NachoShaw
Hey
I resolved this by using some code outside of inventor. The issue was-
As i looped through each ReferencedDocument and changed the reference, i needed to loop through that doc sub references but at that time, they may not have existed in the new folder. My solution was to first loop the assembly and use FileCopy(OldPath, NewPath) to get all of the referenced docs into the new folder and THEN loop the assembly to update the references with the FileDescriptor.
Much less code than copying the new component on each iteration and more robust as my new documents will always exist
Thanks for replying
Nacho
