VBA Macro (Ilogic) to select and color dimensions
ollie_brownBWLCL
ollie_brownBWLCL
Hello, I have been trying to write a macro that will allow me to select all dimensions on a drawing (with multiple views and pages) and re color them. I have been down many rabbit holes but have not been able to solve it.
For Each oDim In oSheet.DrawingDimensions.GeneralDimensions
	Try
		'linear dimension
		If oDim.IntentOne.Geometry.Parent.Name = "VIEW2"
			oDDoc.SelectSet.Select(oDim)
	Catch
		'circle dimension
		If oDim.Intent.Geometry.Parent.Name = "VIEW2"
	End Try
Next
I have this but it only allows me to select dimensions with certain view names "VIEW2"
Andrii_Humeniuk
Hi @ollie_brownBWLCL . This iLogic code can select all GeneralDimensions on all drawing sheets. Also, if you need to change the color of the dimensions, you can use line 15.
Sub main
	Dim iInvApp As Inventor.Application = ThisApplication
	Dim oDoc As Document = iInvApp.ActiveDocument
	If Not TypeOf oDoc Is DrawingDocument Then Exit Sub
	Dim oDDoc As DrawingDocument = oDoc
	Dim oColor As Color = iInvApp.TransientObjects.CreateColor(125, 125, 125)
	Dim oTrans As Transaction
	oTrans = iInvApp.TransactionManager.StartTransaction(oDDoc, "Change color dimensions")
	For i As Integer = 1 To oDDoc.Sheets.Count
		If oDDoc.Sheets(i).DrawingDimensions.Count = 0 Then Continue For
		If oDDoc.Sheets(i).DrawingDimensions.GeneralDimensions.Count = 0 Then Continue For
		Dim oGnrDmns As GeneralDimensions = oDDoc.Sheets(i).DrawingDimensions.GeneralDimensions
		For iD As Integer = 1 To oGnrDmns.Count
			oDDoc.SelectSet.Select(oGnrDmns(iD))
'			oGnrDmns(iD).Layer.Color = oColor
		Next iD
	Next i
	oTrans.End()
End Sub
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
ollie_brownBWLCL
Works a treat thank you!!!
ollie_brownBWLCL
I would like to remove angular dimensions from the selection. Any chance you could help me with that? Inventor rejects the way I have been defining angular dimensions
Andrii_Humeniuk
Hi @ollie_brownBWLCL . No problem. I added a check (line 14) now all angular dimensions are not selected.
Sub main
			If oGnrDmns(iD).Type <> ObjectTypeEnum.kAngularGeneralDimensionObject Then
		Next iD
	Next i
	oTrans.End()
End Sub
ollie_brownBWLCL
Legend!!!
