ILogic rule for loop/iterate through all open documents
tobias
tobias
I would like to have an iLogic rule which applies a certain command on all open drawings (idw's) and sheets.
In this specific case, my command as the folowing:
doc = ThisDoc.Document
		For Each oSheet In doc.Sheets
			For Each oView In oSheet.DrawingViews
				oView.ViewJustification = kCenteredViewJustification
Tobias
The Netherlands
Inventor Pro 2026, Vault Pro 2026, AutoCad Electrical 2026.
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Andrii_Humeniuk
Hi @tobias . This iLogic rule searches for all open .idw files and executes your sample code (lines 6-10).
Sub main
	Dim oInvApp As Inventor.Application = ThisApplication
	For i As Integer = 1 To oInvApp.Documents.Count
		Dim oDoc As Document = oInvApp.Documents(i)
		If System.IO.Path.GetExtension(oDoc.FullFileName) <> ".idw" Then Continue For
		For Each oSheet In oDoc.Sheets
			Next
		Next
	Next i
End Sub
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
tobias
Thanks @Andrii_Humeniuk,
I had a couple of test drawings and the rule worked perfect.
But on some drawings (Checked out Vault drawings) I receive following error:
Any idea?
Tobias
The Netherlands
tobias
I will make a new post for this.
Thanks again @Andrii_Humeniuk !
Tobias
The Netherlands
