Replace reference on sheet and still reference to other sheet
rikard.nilsson
rikard.nilsson
I have a problem that I can't solve and I wonder if someone has a solution.
Let's say I have 2 Sheets with views on a drawing and both sheets references to the same model.
And now I just want to change the reference to only one of the sheets and the other one should reference to the ordinary model.
Is that possible and does someone have an idea how to solve this?
Regards
Rikard
MechMachineMan
Step 1: Copy both sheets to new idw.
Step 2: Replace reference in new idw.
Step 3: Delete sheet 2 in old idw
Step 4: Copy sheet 2 from new idw to old idw.
*Will not be this straightforward if the views are linked between sheets/ you've projected views and dragged them to the next page.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
