Message 1 of 1
Reorder OccurrencePattern to another assembly
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I know that it’s possible to move occurrences from one assembly to another using:
oPane.Reorder(oTargetNode, False, oSourceNode)
However, is there any way to perform the same operation for an OccurrencePattern?
In the Inventor browser, I can drag and drop both a single occurrence and a component pattern into a subassembly, and it works. But when using the API, BrowserPane.Reorder seems to work only for changing order, not for actually moving an OccurrencePattern to a different assembly level.
Is there a supported way in the API to move (demote) an OccurrencePattern to another assembly, similar to how it works in the UI?
Thanks in advance!
If you found it helpful, a "Like" would be much appreciated!
If this post solved your problem, please mark it as "Solution.".
