Reorder DesignViewRepresentations
PetterMoldestad
PetterMoldestad
I want to reorder in my design views (DesignViewRepresentations). I've written the code below. It doesn't fail, but nothing seems to happen. Am I missing something or can it be done otherwise?
Private Sub btnTest3_Click(sender As Object, e As EventArgs) Handles btnTest3.Click
       Dim oInvApp As Inventor.Application
       Dim oInvAssDoc As Inventor.AssemblyDocument
       Try
           oInvApp = GetObject(, "Inventor.Application")
       Catch ex As Exception
           MessageBox.Show("No Inventor open.")
           Return
       End Try
       'Set a reference to active Invetor document.
       Try
           oInvAssDoc = oInvApp.ActiveDocument
           MessageBox.Show("No Inventor assembly document open.")
           Return
       End Try
       Dim oAssCd As AssemblyComponentDefinition
       oAssCd = oInvAssDoc.ComponentDefinition
       Dim oPane As BrowserPane
       ' oPane = oDoc.BrowserPanes.Item("AmBrowserArrangement")
       oPane = oInvAssDoc.BrowserPanes.Item("AmBrowserArrangement:Representations")
       Dim oInvDvr As DesignViewRepresentation
       Dim oInvBrNdPo1 As Inventor.BrowserNode = Nothing
       Dim oInvBrNdPo2 As Inventor.BrowserNode = Nothing
       For Each oInvDvr In oAssCd.RepresentationsManager.DesignViewRepresentations
           Dim sViewName As String
           sViewName = oInvDvr.Name
           If strFunc.InStr(sViewName, "Pos.Nr. 1") > 0 Then
               oInvBrNdPo1 = oPane.GetBrowserNodeFromObject(oInvDvr)
           ElseIf strFunc.InStr(sViewName, "Pos.Nr. 2") > 0 Then
               oInvBrNdPo2 = oPane.GetBrowserNodeFromObject(oInvDvr)
           End If
       Next
       'oPane.Reorder(oInvBrNdPo1, True, oInvBrNdPo2)
       oPane.Reorder(oInvBrNdPo2, True, oInvBrNdPo1)
       oPane.Refresh()
       MessageBox.Show("OK")
   End Sub
chandra.shekar.g
Autodesk Support
Autodesk Support
@PetterMoldestad,
Using Inventor API, Design View Representations are unable to reorder. So, a change request is created with engineering team to investigate and details are given below.
INVGEN - 22427 - Unable to reorder Design View Representations via Inventor API
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
PetterMoldestad
Hello Chandra.
I see. Thank you for the information.
