Add Area Property in every Assembly parts
CCarreiras
Mentor Mentor
CCarreiras
HI!
My goal is to populate the "Area" Property in every Assembly parts, among other properties.
I'm able to manage other custom propertiesand sheet metal extends, but i'm not able to do that with the "Area".
Any help?
In the code below, Sheet metal extends and custom properties are working. Any idea for  Area? Thanks.
SyntaxEditor Code Snippet
Dim openDoc As Document
openDoc = ThisApplication.ActiveDocument
Dim docFile As Document
    For Each docFile In openDoc.AllReferencedDocuments
        	If docFile.SubType.Equals("{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then
             docFile.PropertySets.Item("Design Tracking Properties").Item("Description").Value= "SheetMetal"
             'docFile.ComponentDefinition.Parameters("Thickness").ExposedAsProperty = True
	oParam = docFile.ComponentDefinition.Parameters("Thickness")
	oParam.ExposedAsProperty = True
			oCustomPropertySet = docFile.PropertySets.Item _
			("Inventor User Defined Properties")
		    On Error Resume Next
			oCustomPropertySet.Item("", "SM_Length").Value = "=<Sheet Metal Length>"
				If Err.Number <> 0 Then
					oCustomPropertySet.Add("", "SM_Length").Value = "=<Sheet Metal Length>"
			oCustomPropertySet.Item("", "SM_Width").Value = "=<Sheet Metal Width>"
					oCustomPropertySet.Add("", "SM_Width").Value = "=<Sheet Metal Width>"
oCustomPropertySet.Item("", "Area").Value = "=<Area?????????????>"
	oCustomPropertySet.Add("", "Area").Value = "=<Area???????????????>"
			Else
			docFile.PropertySets.Item("Design Tracking Properties").Item("Description").Value = "Part"
oCustomPropertySet.Add("", "Area").Value = "=<Area??????????????>"
Next
CCarreiras
Curtis_Waguespack
Hi @CCarreiras,
Here's a quick ilogic  example.
I hope this helps.
Curtis
		'get custom prop set
		'get mass prop set
		Dim oMassProps As MassProperties
    	 oMassProps = docFile.ComponentDefinition.MassProperties
		'[ set length
		Try
			'see if iprop exists
			oTest = oCustomPropertySet.Item("SM_Length").Value
		Catch
			'create it if not found
			oCustomPropertySet.Add("","SM_Length")
		End Try
		'set iprop value
		oCustomPropertySet.Item("SM_Length").Value = "=<Sheet Metal Length>"
		'[ set width
		Try
			oTest = oCustomPropertySet.Item("SM_Width").Value
		Catch
			oCustomPropertySet.Add("","SM_Width")
		End Try
		'set iprop value
		oCustomPropertySet.Item("SM_Width").Value = "=<Sheet Metal Width>"
		'[ set area
		Try
			oTest = oCustomPropertySet.Item("Area").Value
		Catch
			oCustomPropertySet.Add("","Area")
		End Try
		'set iprop value
		oCustomPropertySet.Item("Area").Value = Round(oMassProps.Area,0) & " cm^2"
Next
Curtis_Waguespack
Another version of the same rule:
		'get mass prop set
		oArea = Round(oMassProps.Area,0) & " cm^2"
		'add each iprop to am array  list
		'using a "|" to seperate the name from the value
		Dim cIprops As New ArrayList
		cIprops.add("SM_Length" & "|" & "=<Sheet Metal Length>")
		cIprops.add("SM_Width" & "|" & "=<Sheet Metal Width>")
		cIprops.add("Area" & "|" & oArea)
		i = 0
		For Each oItem in cIprops
			'split array list lines into values using the "|" Char
			Dim oProps As String()
			oProps = cIprops.Item(i).Split(New Char() {"|"c})
			'[ set the iProperty
			Try
				oTest = oCustomPropertySet.Item(oProps(0)).Value
			Catch
				oCustomPropertySet.Add("",oProps(0))
			End Try
			'set iprop value
			oCustomPropertySet.Item(oProps(0)).Value = oProps(1)
			i = i+1
		Next 'arraylist item
Next
CCarreiras
Work as required, thank you very much, you rule (iLogic) !!!.
This is a nice workflow to create the "Area" parameter .Preferentially, we will create it at the end of the project, and all will work good.
But... if we want to continue with the work, there's a chance to forget to update these parameters.
In case of Sheet Metal extends, there's no problem because the parameter is a function attached to the sheet metal properties  ....  there's any chance to do the same with the Area?
Being the Area a variable that changes along the process of modeling, it would be possible to create the property, by maintain it associative to the model's area changes?
CCarreiras
Curtis_Waguespack
Hi @CCarreiras,
I would typically create something like this as an external rule and set an event trigger to have it run at the "Before Save" event.
As for an AREA formula, I did not think it existed, but just tried this and it seems to work.
I hope this helps.
Curtis
		cIprops.add("Area" & "|" & "=<Sheet Metal Area>")
		i = 0
			Try
			Catch
			End Try
			'set iprop value
			i = i+1
Next
