Renumber BOM & Sort by Item
Hey guys I'm starting to learn iLogic and I've run into an issue that I know is possible, but nothing I research is helping. Basically, I made an assembly with iLogic rules to set certain values and suppress or un-suppress parts based on options picked in the iLogic form and everything is working beautifully. But now I need to renumber and sort the parts in the BOM from the assembly and have that update the parts list in the drawing as well. Can anybody help with this?
Curtis_Waguespack
Hi @Anonymous ,
Would it be acceptable to sort and renumber the parts list and push those changes back to the BOM, if so here is an example:
https://inventortrenches.blogspot.com/2011/02/ilogic-code-for-parts-lists-title.html
You would just un-comment the Renumber and SaveItemOveridesToBOM lines provided in that example to do those things.
edit:
also here is an example of sorting/renumbering the BOM from the assembly:
https://reghasell.blogspot.com/2012/05/i-have-been-struggling-for-about-week.html
I hope this helps.
Curtis
The second link looks exactly what i want to do, but it's telling me a parameter is incorrect. Can representations affect this?
rhasell
Hi
The code is referencing a custom entry of "TYPE" Change that to your own BOM entries, or remove it.
Below is the updated code, (I don't use it much any more, I use the Parts List Sort)
'Revised 03/2019
'This cut out a few mouse clicks.
' Set a reference to the assembly document.
' This assumes an assembly document is active.
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
' Set a reference to the BOM
Dim oBOM As BOM
oBOM = oDoc.ComponentDefinition.BOM
' Make sure that the parts only view is enabled.
oBOM.StructuredViewFirstLevelOnly = False ' Display All levels
oBOM.StructuredViewEnabled = True
oBOM.PartsOnlyViewEnabled = True
Dim oStructuredBOMView As BOMView
oStructuredBOMView = oBOM.BOMViews.Item("Structured")
' Set a reference to the "Parts Only" BOMView
Dim oPartBOMView As BOMView
oPartBOMView = oBOM.BOMViews.Item("Parts Only")
Call oStructuredBOMView.Sort("BOM Structure", True, "Stock Number", True)
oPartBOMView.Sort("BOM Structure", True, "Stock Number", True)
MessageBox.Show("Done", "Sort BOM")
''Re-Number the BOM
Call oPartBOMView.Renumber(1, 1)
Call oStructuredBOMView.Renumber(1, 1)
Reg
2026.1
rhasell
Hi
This is actually the real code that I use now days, it sorts by item, but does not renumber. (That's done in the drawing)
'Revised 03/2019
'This will Sort the BOM by Item Number only
'As the BOM is controlled by the Parts List, and I just want to make viewing easier
Dim oBOM As BOM
'Call oStructuredBOMView.Sort("BOM Structure", True, "TYPE", True, "Stock Number", True) ' Old, left for reference
Call oStructuredBOMView.Sort("Item", True)
Call oPartBOMView.Sort("Item", True)
'oPartBOMView.Sort("BOM Structure",True ,"TYPE",True ,"Stock Number",True) 'Old, Left for reference
'''The following is not needed anymore
''Re-Number the BOM
'Call oPartBOMView.Renumber(1, 1)
'Call oStructuredBOMView.Renumber(1, 1)
Reg
2026.1
