Rename Browser Nodes API?
amitabhVA4SD
amitabhVA4SD
Hello All,
Is there a direct API to mimic the "Rename Browser Nodes" option without having to loop over all the occurrences and sub occurrences in the tree? I am looking for some Property of the Browser Pane or Inventor Command.
This is to mainly handle the below issue
Amitabh Mukherjee
JelteDeJong
I don't think there is a fast way to do this using the browser. But I think that you can do this fast with an occurrence search function. something like this:
Sub Main()
    Dim doc As AssemblyDocument = ThisDoc.Document
    Dim occs As IEnumerable(Of ComponentOccurrence) = findAllWhere(doc,
	    Function(occ)
			'Contains' is case sensitive
	        Return occ.Name.Contains("void-vectratest-UB3_4PA_003")
	    End Function)
    Dim i = 1
    For Each occ As ComponentOccurrence In occs
        occ.Name = "test" & i
        i = i + 1
    Next
End Sub
Public Function findAllWhere(doc As AssemblyDocument,
            predicate As Func(Of ComponentOccurrence, Boolean)) As IEnumerable(Of ComponentOccurrence)
    Dim list As IEnumerable(Of ComponentOccurrence) = doc.ComponentDefinition.
        Occurrences.Cast(Of ComponentOccurrence).
        Where(predicate)
    Dim assemblyList As IEnumerable(Of ComponentOccurrence) = doc.ComponentDefinition.
        Where(Function(o) o.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject)
    For Each assOcc As ComponentOccurrence In assemblyList
        If TypeOf assOcc.Definition Is VirtualComponentDefinition Then Continue For
        Dim assDoc As AssemblyDocument = assOcc.ReferencedDocumentDescriptor.ReferencedDocument
        Dim listToAdd As IEnumerable(Of ComponentOccurrence) = findAllWhere(assDoc, predicate)
        list = list.Concat(listToAdd)
    Next
    Return list
End Function
Jelte de Jong
Blog: hjalte.nl - github.com
amitabhVA4SD
Sorry for the delay in responding and Thank you @JelteDeJong
This is helpful!
