Remove an occurrence from an ObjectEnumerator (or ObjectCollection)
oransen
oransen
I have an object collection obtained from the first Element of a pattern. I'd like to remove one object occurrence from that object collection, but I get a syntax error whatever I try. Here's the code:
Dim i As Integer
Dim sCell as String
Dim oDoc = ThisDoc.Document
Dim oDef As AssemblyComponentDefinition
oDef = oDoc.ComponentDefinition
Dim oPattern As RectangularOccurrencePattern
oPattern = oDef.OccurrencePatterns.Item("NomePattern")
Dim oCompOcc As ComponentOccurrence
Dim Elements as OccurrencePatternElements
Elements = oPattern.OccurrencePatternElements()
Trace.WriteLine("the pattern has " + Str(Elements.Count) + " elements" )
' 1,1 is the first set of objects in the pattern
Dim OPT as OccurrencePatternElement
OPT = oPattern.OccurrencePatternElement(1,1)
Dim Components As ObjectsEnumerator ' ObjectCollection
Dim CompOcc As ComponentOccurrence
Dim CompDef As PartComponentDefinition
Dim sToDelete As String
Dim sOccName As String
Dim iColonPos As Integer
Dim sInstanceName As String
Components = OPT.Components()
sToDelete = "30295480"
' Look at each occurrence and remove that with the sToDelete name
For Each CompOcc in Components
' For i = 1 To Components.Count
	'CompOcc = Components.Item (i)
	CompDef = CompOcc.Definition()
	sOccName = CompDef.Document.FullFileName()
	sInstanceName = CompOcc.Name ()
	iColonPos = InStrRev (sInstanceName,":") ' "ABCDE:1" iColonPos becomes 6
	sInstanceName = Left(sInstanceName,iColonPos-1)
    Trace.WriteLine("Component " + Str(i)+ " filename: " + sOccName + " in pattern name: " + sInstanceName)
    If sInstanceName = sToDelete Then
	   ' ***HERE*** .... how to I remove the ith occurrence from the ObjectsEnumerator
	   ' Trace.WriteLine ("Remove..." + Str(i))
	   '  Components.Remove (i)
	   ' CompOcc.Delete
    End If
Next
All seems to work, I get the names written out correctly, but I cannot remove any of the objects from the first Element. Manually this would move the occurrence from the first Pattern's element into the root of the assembly. But niether Delete nor Remove seemt to work.
I bet I've missed something obvious...
HermJan.Otterman
maybe this helps..
https://forums.autodesk.com/t5/inventor-customization/exclude-remove-component-occurrence-from-exist...
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
oransen
Thanks for that link. Now I seem to have taken a step forward:
        ' This now compiles at least...
	Components.RemoveByObject (CompOcc)
	Exit For
End If Next OPT.Components() = Components ' ERROR because OPT is read only
So Components.RemoveByObject compiles, but when I try to replace the old list with the new list (last line above) I get an error because OTP is read only...
HermJan.Otterman
are you using iLogic? or vb.net?
in iLogic try this code,
		 Dim oAsmDoc As Inventor.AssemblyDocument
        oAsmDoc = ThisApplication.ActiveDocument
        Dim oAsmCompDef As AssemblyComponentDefinition
        oAsmCompDef = oAsmDoc.ComponentDefinition
        Dim oAsmOccPattern As OccurrencePattern
        oAsmOccPattern = oAsmCompDef.OccurrencePatterns.Item(1)
        Dim oAsmCompOcc As ComponentOccurrence
        oAsmCompOcc = oAsmOccPattern.ParentComponents.Item(1)
        Dim oOccurrences As ObjectCollection
        oOccurrences = oAsmOccPattern.ParentComponents
        oOccurrences.RemoveByObject(oAsmCompOcc)
        oAsmOccPattern.ParentComponents = oOccurrences
does it remove an element ?
maybe remove the ( ) in the last line
(what is OPT?)
Herm Jan
oransen
Hi Herm Jan Otterman
Magic, perfect, thanks for pointing me in the right direction!
