Exclude/remove component occurrence from existing rectangular/circular pattern
Hi everybody,
I am trying to create VBA macro in IV2011 which will delete all occurrences of content center parts from an assembly.  I found the way how to delete occurrences from an assembly, but I can't find the way how to delete occurrences when they are members of  rectangular or circular pattern. I was trying to exclude them from pattern but code which I wrote doesn't work (see below). It doesn't give me any error message.  Any suggestion what I did wrong?
Public Sub RemoveOcc()
    Dim oDoc As Document
    Set oDoc = ThisApplication.ActiveDocument
    Dim oAsmDoc As AssemblyDocument
    Set oAsmDoc = oDoc
    Dim oAsmCompDef As AssemblyComponentDefinition
    Set oAsmCompDef = oAsmDoc.ComponentDefinition
    Dim oAsmOccPattern As OccurrencePattern
    Set oAsmOccPattern = oAsmCompDef.OccurrencePatterns.Item(1)
    Dim oAsmCompOcc As ComponentOccurrence
    Set oAsmCompOcc = oAsmOccPattern.ParentComponents.Item(1)
    Call oAsmOccPattern.ParentComponents.RemoveByObject(oAsmCompOcc)
End Sub
Thank you,
TerryWen
Stan,
Your code should not work, because many Inventor APIs, which return a collection, return a temporary colletion, which means event you changes the collection you get, it will not affect the object from which the collection you get.
The only thing you need to do is to set the collection back to the object. so following code will work, i only added the code marked as green.
    Set oAsmDoc = oDoc
    Dim oOccurrences As ObjectCollection
    Set oOccurrences = oAsmOccPattern.ParentComponents
    Call oOccurrences.RemoveByObject(oAsmCompOcc)
    oAsmOccPattern.ParentComponents = oOccurrences
End Sub
hope it's useful to you.
-terry
