Remove all text overrides from dimensions in drawing
Is there a way to uncheck all of the "hide dimension value" boxes on overridden dimensions in a drawing?
I know you can select all of the overridden dimensions but I am struggling to find a way to mass edit all of these dimensions removing their overrides.
I was maybe thinking that you could create a different dimension style and have that one set to not allow dimension overrides but I can't find a way to set that sort of parameter.
Any help is greatly appreciated.
S_May
Hallo, und willkommen im Forum.
Bitte bei Fragen zum System bitte immer mit angeben:
• Aktuelle Inventor Version mit aktuelle SP
• Betriebssystem mit Grafikkarte, RAM, CPU usw.
Bei Fragen zum Modellierung mit angeben:
• Modelle oder Baugruppen mit pack and go packen und anhängen
• Bilder der Probleme
•screencast
https://knowledge.autodesk.com/de/community/screencast
https://knowledge.autodesk.com/de/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2...
Und dann kann es schon losgehen mit der Analyse…
martin.jacko
I think you can use VBA script for this purpose.
Sub Reset()
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    Set oSheet = oDoc.ActiveSheet
    Dim oLinDim As DrawingDimension
    For Each oLinDim In oSheet.DrawingDimensions.GeneralDimensions
    If oLinDim.ModelValueOverridden Then
        oLinDim.HideValue = False
    End If
    Next
End Sub
Martin
