Remove Add-in from Add-In manager
JhoelForshav
Mentor Mentor
JhoelForshav
I recently tried to create an Inventor Add-in for the first time. The add-in failed to load for some reason and eventually i decided to just start over. This add-in however, is still in the list in Add-in manager. This really annoys me. There are no files left in my computer from this add-in. I suppose i need to unregister it from inventor somehow?
I've checket both C:\ProgramData\Autodesk\Inventor 2018\Addins and C:\Users\"username"\AppData\Roaming\Autodesk\Inventor 2018\Addins and there are no files associated to this add-in there.
Does anybody here have an idéa of how i can get rid off it?
JhoelForshav
Never mind. I found it!
I used the project template in visual studio to create an inventor add-in. Apparently when i build it creates a folder with the add-in name at C:\Users\MyName\AppData\Roaming\Autodesk\ApplicationPlugins
Deleting this folder does the trick 🙂
chandra.shekar.g
Autodesk Support
Autodesk Support
@JhoelForshav,
Can you please check at this location "C:\Users\"User Name"\AppData\Roaming\Autodesk\ApplicationPlugins" ? Delete both files and folder.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
JhoelForshav
Thank you @chandra.shekar.g!
Indeed that's how its done. Found the folder right before you posted this 😄
