Help. intersection point between an sketch and a WorkPlane with VBA?
Hi all!
How could I find the intersection point between an sketch and a WorkPlane? (but using VBA)
I got an example:
I want to use this function:
(in English is: "intersection of line and plane/Surface)
But I don´t know how to program it.
Thanks in advance!
BrianEkins
Here's some code that demonstrates using the API (WorkPoints.AddByCurveAndEntity method) to do the equivalent of the command you pointed out.  The command and the API are limited to using a linear entity (sketch line, linear edge, work axis) and a plane (planar face or work plane).  The sample expects you to have a work plane and sketch line selected before you run the macro.
Public Sub LinePlaneWPCreate()
    Dim partDoc As PartDocument
    Set partDoc = ThisApplication.ActiveDocument
    If partDoc.SelectSet.Count <> 2 Then
        MsgBox "The work plane and sketch line must be selected."
        Return
    Dim skLine As SketchLine
    Set skLine = Nothing
    Dim wp As WorkPlane
    Set wp = Nothing
    If TypeName(partDoc.SelectSet.Item(1)) = "SketchLine" Then
        Set skLine = partDoc.SelectSet.Item(1)
    If TypeName(partDoc.SelectSet.Item(2)) = "SketchLine" Then
        Set skLine = partDoc.SelectSet.Item(2)
    If TypeName(partDoc.SelectSet.Item(1)) = "WorkPlane" Then
        Set wp = partDoc.SelectSet.Item(1)
    If TypeName(partDoc.SelectSet.Item(2)) = "WorkPlane" Then
        Set wp = partDoc.SelectSet.Item(2)
    If skLine Is Nothing Or wp Is Nothing Then
        Return
    Dim newWP As WorkPoint
    Set newWP = partDoc.ComponentDefinition.WorkPoints.AddByCurveAndEntity(skLine, wp)
End Sub
Brian Ekins
Excellent. Thanks for your help.
It actually Works because I get the workpoint... but i need the coordinates and with your method I can't.
I modified the code for my case:
Dim skLine As SketchControlPointSpline
Set skLine = partDoc.ComponentDefinition.Sketches(2).SketchControlPointSplines(1)
Dim wp As WorkPlane
Set wp = partDoc.ComponentDefinition.WorkPlanes.Item(3)
but in this way I don't know how to get the coordinates because I wanna use it later.
BrianEkins
Since you referenced a specific work point command, I assumed that you wanted to create a work point.  Here's the additional code to get the coordinate of the created work point.
Dim coord as Point
Set coord = newWP.Point
MsgBox coord.X & ", " & coord.Y & ", " & coord.Z
If all you need is the coordinate and don't care about the work point, then there's another way that just calculates the intersection without creating any new entities.
Public Sub SketchPlaneIntersection()
    Dim sketchCurve As SketchEntity
    Set sketchCurve = ThisApplication.CommandManager.Pick(kSketchCurveFilter, "Select sketch entity.")
    Dim sl As SketchLine
    Dim wp As WorkPlane
    Set wp = ThisApplication.CommandManager.Pick(kWorkPlaneFilter, "Select work plane.")
    Dim results As ObjectsEnumerator
    Set results = ThisApplication.TransientGeometry.CurveSurfaceIntersection(sketchCurve.Geometry3d, wp.plane)
    If results Is Nothing Then
        MsgBox "No intersection was found."
    Else
        Dim i As Integer
        For i = 1 To results.Count
            MsgBox "Intersection " & i & ": " & results.Item(i).X & ", " & _
                                                results.Item(i).Y & ", " & _
                                                results.Item(i).Z
        Next
End Sub
Brian Ekins
Thanks MR. Brian!
It worked good. Thanks for all your Help.
